Question about kawasaki PVS1965 Portable DVD Player
Cannot find a new battery batt-2p - kawasaki PVS1965 Portable DVD Player
    Brigadier General:
  • 3,917 Answers
Please check this links bellow for the battery, hope it helps:-
http://www.mdsbattery.co.uk/departments/department002.asp?Brand=KAWASAKI&DepartmentName=Portable+DVD+Player+Batteries&DepartmentID=184
http://batteries.batterymart.com/kawasaki-portable-dvd-player-rechargeable-battery--list
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Jan 01, 2011
What is the value of p if 2p/12=58
Let's work it out.
2p/12=58
2p/12*12=58*12
2p=696
2p/2=696/2
p = 348
Now let's check it
2*348/12=58
696/12=58
58 = 58
Always work out the equation to your final solution.
Semper Fi,
Z
Feb 13, 2018 | Homework
Why wont the top 30 amp breaker won't reset?
YES!
New breaker is cheaper than a service call and quicker than tearing the dryer apart.
Jul 10, 2014 | Cutler Hammer Bq Circuit Breaker Bq230240...
Where are the side impact sensors located on a 2001 honda accord?
Usually at the base of the 'B' pillar (between the doors) behind the plastic trim.
______________
maxiscan ms509
Sep 12, 2012 | 2001 Honda Accord
Need a battery- BATT-2P for DVD player-Kawasaki PVS1080
The battery is difficult to replace, I cannot find any after market batteries to replace your current one.
You can try buying a generic battery "extender" see here
I have used these in the past and they have worked well.
Jan 25, 2011 | Video Game Consoles & Games
Battery was low and put in new battery,problem SRC Light stays on how can I reset the SRC light?
I'm guessing you mean the SRS light, yes. When you have a bad battery the battery voltage can drop below 10 volts. The SRS unit detects this voltage loss and set a DTC (diagnostic trouble code) for an internal SRS unit failure. You have to erase the DTC memory. You'll need an SCS service connector tool (P/N 07PAZ-0010100) You can order one from your local honda dealer. Don't worry its not more than $10. Then you'll have to find the MES 2pin connector located in the upper right hand corner of the drivers underdash fuse box. It can be gray, green or yellow in color. 1.)Turn the ignition switch off. 2.)Unplug the MES connector from the fuse box and plug your SCS special tool into the MES connector. 3.) Turn the ignition switch on. 4.) The (red) SRS light in the dash will come on for 6 seconds and then go off. Remove the SCS tool from the MES (2P) connector within 4 sec. after the SRS light went off. 5.) The SRS light comes on again. Reconnect the SCS tool to the MES (2P) connector within 4 seconds after the SRS light came on. 6.) The SRS light goes off. Remove the SCS tool from the MES (2P) connector within 4 sec. 7.) The SRS light indicates that the memory is erased by blinking twice. 8.) Turn the ignition switch off and wait ten seconds. You may have to do this procedure a few time to get the steps correct. If this sounds to complicated I'm sure your local Honda dealer would be happy to reset the light for you for no charge. Just let them know that the battery was recently replaced and you think that the SRS light came on due to low battery voltage. -Hope this helps:)
Jan 13, 2010 | 1997 Honda Civic
Battery problem
Remove stain from batt. location , spray it WD40 inside batt. compartment then use NiMH batt. enelop white color
Jun 17, 2009 | Canon PowerShot A570 IS Digital Camera
Battery is not charging nokia
check batt model r it arthorised batt and check charger and batt model no
Jan 23, 2009 | Nokia 6630 Cellular Phone
kawasaki PVS1965 Portable DVD Player Logo
Top kawasaki Televison & Video Experts
wayne chamberlain
Jaime Hernandez
Davor Krstevski
Davor Krstevski
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
