Question about Graco Baby Gear
How to restring belts in front facing seats - Graco Baby Gear
Do i need to turn off front passenger air bag when using a forward facing child seat
Yes, you need to turn off front passenger air bag when using a forward facing child seat.
Good luck.
Oct 30, 2010 | 2004 Volkswagen Golf
How to install front facing baby start car seat
Identify the parts. A car seat will likely come with two parts - the base and the actual cradle itself. The base part is what will actually be in the car, while the baby cradle (seat) is removable and portable - the baby cradle can be taken out of the car and easily attaches to most grocery carts (the front part where bigger kids sit) and restaurant high chairs (move the standard restaurant high chair upside down and you will have yourself a cradle holder).
Give it a try. Place the booster flat on the backseat of your car and run the seat belt around it to hold it down - read your instructions and they will have detailed graphs on how the seat belt hurts. Also look at your car manual as they will have special instructions and buckles for car seats
Get confirmation. Move your baby seat cradle on top of the base (remember, it always faces the rear, when your child is old enough you will have to buy a different type of car seat that faces forward towards you). With your hand, sternly move your baby car seat from side to side, if the cradle is easily swaying your car booster is not securely fastened. Remove the cradle and pull the car seat belt as snug as you can and try again
Get double confirmation. Call your local fire department and make an appointment to stop by - they will check and confirm your car seat is installed securely. Remember, this could save your child's life so 10 minutes with your local fire department is only a very small inconvenience!
Oct 20, 2010 | Baby Gear
1995 Honda Accord Car seat install problem
I can't be of much help, except to indicate what Honda says about the seats, and to give you a URL to look at:
Using a Seat Belt Locking Clip
Always use a seat belt locking clip when you secure a child seat to your car with a lap/shoulder belt. This helps prevent the seat from shifting position or overturning. A locking clip is usually included with the child seat. If you need a clip, contact the seat's manufacturer or a store that sells child restraints.
The URL will take you to a more complete reference to your car manual regarding child restraints.
https://techinfo.honda.com/rjanisis/pubs/om/AC9595/AC9595O00020A.pdf
Hope this helps you.
Nov 18, 2009 | 1999 Honda Accord
How do we fix front passenger side seat belt retractor on 1999 Ford Taurus? It will not pull out....
you may have to remove the bolt that holds the buckle to the floor. Try to push the belt into the retractor and see if it frees up.
I assume you are saying it is in the locked mode. It has an automatic lock mode for holding a child seat. When the belt is pulled all the way out, it goes into locking mode. You will hear it ratchet when the belt starts going back in.
Section 01-20A: Restraints, Active 1999 Taurus, Sable Workshop Manual
DESCRIPTION AND OPERATION Safety Belt, Lap/Shoulder The dual locking mode retractor on the shoulder belt portion of the combination lap/shoulder safety belt for the front seat passenger and rear seat outboard passengers operates in two ways:
  1. In the vehicle sensitive (emergency locking) mode, the shoulder belt retractor will allow the occupant freedom of movement, locking tight only on hard braking, hard cornering or impacts of approximately 8 km/h (5 mph) or more. The front and rear outboard seat belt retractors can also be made to lock by pulling/jerking on the belt.
  1. In the automatic locking mode, the shoulder belt retractor will be automatically locked and remain locked when the combination lap/shoulder safety belt is buckled and does not allow the occupant freedom of movement. This mode provides tight lap/shoulder belt fit on the occupant and on a child safety seat or infant carrier installation restraint.
  1. When the combination lap/shoulder belt is unbuckled and allowed to retract completely, the retractor will switch to the vehicle sensitive (emergency) locking mode.
sxh~us~en~file=ani_caut.gif~gen~ref.gif WARNING: REAR-FACING INFANT SEATS SHOULD NEVER BE PLACED IN THE FRONT SEATS.
The automatic locking mode must be used when installing a child safety seat on the front passenger seat and rear outboard seats where dual locking retractors are provided
Apr 21, 2009 | 1999 Ford Taurus
Need a car seat manual
Types of car safety seats at a glance
The chart below is a quick guide on where to start your search. However, it’s important to read more about the features and how to use your car safety seat.
Age Type of Seat General Guideline Infants Infant seats and rear-facing convertible seats All infants should always ride rear-facing until they are at least 1 year of age and weigh at least 20 pounds. Toddlers/Preschoolers Convertible seats It is best to ride rear-facing as long as possible. Children 1 year of age and at least 20 pounds can ride forward-facing. School-aged children Booster seats Booster seats are for older children who have outgrown their forward-facing car safety seats. Children should stay in a booster seat until adult belts fit correctly (usually when a child reaches about 4' 9" in height and is between 8 and 12 years of age). Older children Seat belts Children who have outgrown their booster seats should ride in a lap and shoulder belt in the back seat until 13 years of age.
Mar 28, 2009 | Evenflo Ultara I Premier
Turn airbag off for 5 series bmw
Hi , if you visit a dealer they will be able to let you know how much it will cost to deactivate the passenger air bag.
Mar 14, 2009 | BMW 5 Series Cars & Trucks
Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Instructions on how to instal a second hand safe-n-sound car seat
how do i put the straps back on through the cover
Oct 19, 2008 | Baby Gear
How do I install a child seat in a 1998 toyota corolla?
as long as you have the sealtbelt properly fitted on the childs chest. there wont be any problems. btw, i have a 1979 toyota corona. so that makes our cars nearly the same.
Mar 24, 2008 | Baby Gear
Baby Gear Logo
41 people viewed this question
Top Graco Baby Gear Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
