What is the low and high presssures for the goodman air conditioner of one and a half tons Model GSC130181AA
    Sergeant:
  • 288 Answers
Its all relative to the ambient temperature, the hotter it is the higher the pressure. The best way to check for proper freon charge is to take the suction line temperature about 12" from the compressor. Convert the reading from pressure to the temp on the the low gauge band for R-22. Ideally, there should be a 20 degree difference between the two temperatures, this is called "superheat". First make sure the blower fan is on high speed (the black wire) and the air filter is new. The suction or low side pipe should have some sort of insulated wrap on it. Also the evaporator and condenser coils must be clean as well and unobstructed, all these can effect the reading of the gauges. Got it? Good luck. And people wonder why HVAC techs charge so much for their services.
Posted on Jul 08, 2008
WHERE IS THE Goodman GSZ130301 RESET BUTTON ON CONDENSOR
No reset button. As for low/high pressure switches they reset on their own when the problem is corrected. Usually low refrigerant.
May 03, 2014 | Goodman Manufacturing Goodman GSZ130301...
What are GSC130481AC low and high pressure readings
65to 78 psig on low side 210 to 270 on high side. higher values when house is warm.
May 01, 2014 | Goodman Heating & Cooling
Low to zero pressure on low side test port
150 is low for high side pressure. may have to add more r-22 to system. if you had a blockage high side pressure should be higher. have you turned both service valves at condensor ccw completely?
Apr 20, 2014 | Goodman CKL42AR42 Air Conditioner
2 ton condensing unit w/ 3 ton evap 100 suction 175 discharge
The orifice or the expansion valve are for a three ton unit and you only have a 2ton...so too much gas is going through causing low discharge and high suction... install correct orifice or TXV and you'll be okay...
heatman101
Aug 03, 2011 | Goodman CKL24AR24 Air Conditioner
How many tons is a Goodman Central Air Unit with Model Number CKL30-IE?
That is a 2.5 ton system. The model numbers are as indicated:
24- 2 ton.
30- 2.5 ton.
36- 3 ton.
42- 3.5 ton.
48- 4 ton.
60- 5 ton.
Hope this answers your question!
Jul 15, 2010 | Goodman CKL60AR60 Air Conditioner
AC not cooling
first off you should have a four ton unit. what is your super heat? is it pulling attic or outside air?
May 27, 2010 | Goodman CLQ36AR49 Air Conditioner
Do you know how I can get a Goodman Ht pmp Manual
this manual willl not help your system perform better , have a qualified tech check your sub-cooling. temp diff, and match your piston with your coil. many goodman systems may say they are 3 or 4 ton but are half a ton smaller than advertised at the compressor. a three ton system will have a two and a half ton compressor
Oct 01, 2009 | Goodman Heating & Cooling
My fan motor runs to slow and needs to be speeded up. The fan motor has been changed to a A O Smith. Air conditioner is a Goodman 3 ton.
AO Smith motor speeds are Red low Blue med. And black high. Just unplug from fan switch plug in new speed. Turn power of first. Rus
Jun 17, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
