Question about Samsung ML-2240 Laser Printer
Thermister open - Samsung ML-2240 Laser Printer
  • 125 Answers
Try find for a deffective micro switches or some other parts like resistors in the main board.
Posted on Jan 01, 2011
My lg wm1832cw washer was in spinmode when it made a bam noise and lost power. I had to change the board ans when I did the upside down f and e came on. I changed the thermistor but am still getting the...
check the wire harness from main board to thermister. tE error code is either an open or shorted thermister. If you replaced the main board and thermister, the only other option you have is a bad harness. Reseat connectors on the main board and all along the harness to the thermister
Feb 10, 2013 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Samsung dryer is showing TO, what does it mean?
Dryer thermister is open. Thermister Open. Thermisters will change in resistance with temperature changes. The control relies on reading from this thermister so it can make a determination of whether or not to turn the heat on. If it is open then the control don't know what the air temp is inside the dryer and therefore it shuts down and declares an error. The thermister is mounted on the blower where it gets the air coming out of the drum on the way out the back. The fuse is right next to it. I bet you would like a service manual wouldn't you? SAMSUNG DRYER MANUAL
Note: dryer error codes are on page 32.
Dec 31, 2012 | Samsung DV328AE Electric Dryer
HOTPOINT FRIG GEHSM25GFRESA THERMOSTATS WERE ON 5 NOW ON 1 TO KEEP UNIT FROM GETTING TO COLD
Either your auto damper has frost blocking it open or the=> WR55X10025 Thermister is defective.
Try using a hair drier to force warm air into the damper to see if the damper will close better by melting any ice that may have the damper stuck open.Here is the=> WR09X10050 Damper Thermister Assembly Instructions on how to change this part can also be found on the same page HERE If you have any questions please ask, Thanks Sea Breeze
WR09X10050 Damper Thermister Assembly Below
Jul 11, 2012 | Hotpoint HSS25GFP Side by Side...
I have a whirlpool cabrio dryer model WED6600VWD. What does the F1 error code mean?
The F1 error code means that the thermister (cycling thermostat) has a open circuit and should be replaced.
To check the thermister you would need to DISCONNECT POWER TO THE DRYER remove the lower small front panel below the main one where the door is at and using a digital meter set to measure ya would remove the wires from the thermister and check for appx. 5,000- 7,500 ohms at room temperature.
If the ohms at within 5 thousand to 7thousand 5 hundred at room temp. the thermister is good and the control board is what the problem is....if the ohms is way lower or higher that 5-7,500 ohms the thermister is going to be what would need to be replaced.
Here is what the thermister looks like
I hope i have been able to help you fix your dryer,
GENE
Oct 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have more than three machine Xerox PE16, One of them give me Error "Open Heat Error" What can i do
OPEN HEAT ERROR (When warming up, it has been lower than 68 °C over 25 sec)
Meaning : Thermister is not connected to main board or contact point is loose at power on.
Solution : Check thermister contact point, Heating Lamp & Thermostat.
Aug 08, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
My KUIC15prts2 is producing way too much ice. What do I need to check to make it stop?
there is a bin thermister, when you open the door look on the right side of the bin and you will see a white (L) shaped bar thant has wires connected above the cutter grid. the bar (bin thermister) is what senses the ice level, when ice reaches it the machine would turn itself off. replace this bin thermister. the part# is 2313633
Jan 20, 2011 | KitchenAid KUIS18NNT 18" Automatic Ice...
Oki C3200 message on screen says '171 Fatal
Yes it can be saved, it is indicating the fuser thermister is open or below temperature. Try opening the printer and restarting it. If that does not fix it you may have to replace the thermister or the fuser
Jan 18, 2010 | OKI C3200n Led Printer
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
Jan 14, 2010 | Sharp AR-5320 Black and White Copier
Samsung ML-2240 Laser Printer Logo
27 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
