Question about KLH Audio Players & Recorders
KLH SW90, subwoofer ;old but hardly used .I want to use it with new surround system but lost the manual ; What is the difference between the bare wire ( "high level") inputs and the RCA jack inputs ?
3 Suggested Answers
SOURCE: connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Posted on Jan 07, 2009
    SOURCE: KLH ASW10-120 Subwoofer My KLH ASW10-120
    Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
    Posted on Jan 26, 2010
    KLH ASW8-100b Sub woofer. I need to know how to hook it up to my surround sound
    Some specific model numbers might lead us to specific manuals and specific instructions.
    Depends on your source and its amplifer complement. Some can drive a subwoofer directly while others just produce a Line Level subwoofer output for use by a separate amp feeding a subwoofer or self-amplified sub.
    The set-up of the source to produce a subwoofer output is totally dependent on its design. Generally, you have to 1) tell it you have a sub, 2) define how bass will be routed or shared among your various speakers accordingto their bass-handling capacities, 3) using test tones, set the relative ludness and crossover settings so you have a uniform sound field.
    To find a manual, maybe run it by the manufacturer
    Mar 17, 2011 | KLH ASW8100 Subwoofer
    What speakers are beneficial with this receiver? I want to have surround sound from my TV and also from my other components - CDs and old record player.
    Well to get the full effect of 5.1 surround you will need 2 front speakers, 1 subwoofer, and 2 rear speakers. Personally I used 2 tower speakers, 2 rear speakers and a subwoofer. Match the speakers with the RMS wattage of your Receiver. (100x5) or roughly 50 watts per speaker. Yamaha, KLH, Philips are pretty good speakers.
    May 13, 2009 | KLH R5100 Receiver
    Jamo i330 i-pod dock has one channel out
    I WOULD LIKE 2 NO IF I CAN RESET MY PASSWORD 4 KLH SURROUND SOUND SYSTEM. I BOUGHT AT A SALE AND THERES NO WAY I CAN FIND OUT PASSWORD. IT IS A KLH SURROUND SOUND SYSTEM DVZ-2500 MODEL # IS 0044224000657.I WOULD ALSO LIKE 2 NO IF AND WHERE I CAN GET A MANUEL....
    Mar 04, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
    My klh subwoofer has R&L connections to speaker and R&L connections to amplifier, but my new amp has a RCA cable connection plug-in. Any way I can use the old subwoofer with the new system?
    Yes, you use a subwoofer cable and hook it into the mono rca jack in the back of the sub. or you can use a Y splitter 1 female to 2 males. or if your amp has 2 sub outputs (L&R) then use both. I do believe it's said that if you use the high level input, it's better. I forgot why...
    Oh yeah. the difference between the 2 is a high level input allows the currant from the amp to pass through the sub, thus allowing the continuation of wattage to your other speakers.
    Low level input is only taking a audio signal from the amp. No power is being sen through the connection.
    Jan 01, 2009 | KLH ASW10-120 Subwoofer
    Loud humming buzzing sound coming from subwoofer
    make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
    Dec 16, 2008 | KLH HTA-4906 System
    KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
    Is sub out turned on on the reciever? Some have a setting that doesnt use the sub out, like 2 channel.
    Jul 30, 2008 | Audio Players & Recorders
    Lost instructions
    The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
    Here's how you hook them up:
    - The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
    - Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
    - Your center speaker is connected to your receiver terminals marked 'Center'
    - Your rear speakers are connected to your receiver terminals marked 'Surround'
    That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
    Jan 07, 2008 | KLH HT-9900 System
    117 people viewed this question
    Top KLH Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Electro Med Services...
    Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
