Question about General Electric Refrigerators
Happy New Year! I have a GE side by side refridgerator (TFX25JRYA) that is not cold enough on the fridge side and the freezer has ice/frost on the back. Last night I cleaned the coils, but this has not improved the temp issue. I am about to pull everything out of the freezer and clean the inside, is there something else that I can do before calling a repair man? Any idea what may be causing this? Thanks for your help
catriver
  • 878 Answers
SOURCE: freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Posted on Aug 28, 2006
Amigaman
  • 248 Answers
SOURCE: refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Posted on Nov 12, 2007
bobotfel
  • 236 Answers
SOURCE: side by side w/ dipenser ge refridgerator
Your unit is under charge and need to check for leak. Please call qualified technician.
Posted on Jan 03, 2008
SOURCE: ge side by side not cold enough in fridge or freezer
the fan behind the freezer panel inside
Posted on May 31, 2008
SOURCE: GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Posted on Jul 30, 2008
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling, freezer is working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fdite
Oct 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Aug 03, 2009 | Amana ABB1927DE Bottom Freezer...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
Sep 17, 2008 | Refrigerators
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
46 people viewed this question
Top General Electric Refrigerators Experts
Dan Webster
Dan Webster
Darrell
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
