Question about Dell PowerEdge 830 Server
How do I open my power edge to replace RAM. I t looks like it is riveted in back
    Problem Solver:
  • 17 Answers
You can conveniently crack open the case without tools by swinging open the door that covers the front bezel, using your fingers to untwist a setscrew that lies underneath, then sliding off the side panel
Posted on Jan 01, 2011
How do I remove the front driver side power window switch on a 2008 Buick Enclave
Armrest Door Pull
Remove Rubber Cover
Remove 10mm *****
The first step is to pry out the plastic trim plate behind the chrome colored door release handle using a small flathead screwdriver.Then remove the 10mm ***** behind the plate using a ratcheting wrench with an extension bar attached.
Next pry out the rubber cover at the bottom of the door pull located in the center of the arm rest. Use a Torx T-25 (star bit) screwdriver to remove the two screws.
Remove Torx T25 Screws
2 T-25 Torx & 1 10mm *****
Pry Up Arm Rest Panel
Use a flathead screwdriver to pry up the rear of the plastic arm rest panel. There is a plastic hook at the front of the panel, so only pry it up from the rear edge.
Lift Rear End First
Plastic Hook At Front of Panel
Power Window Connector
After you lift out the arm rest panel, you'll need to disconnect the power connector for the window and door lock switches.
Push Connector Release Tab
Power Connector Unplugged
Two More T25 Screws
Push on the release tab with a flathead screwdriver and pull out the power window / door lock connector.Use a Torx T25 screwdriver to remove the two screws located below the arm rest panel.
Remove T25 Torx Screws
Outer Edge of Panel
Push In Center of Fastener
Then move to the outer edge of the door panel and locate the two small round fasteners. Use a small screwdriver to pop in the center pins of the two fasteners.
Pull Out Plastic Rivet
Black Plastic Fastener Removed
Remove Lower Fastener
Pull out the two plastic rivet fasteners and set them aside in a safe place.
Pull Panel Away From Door
White Plastic Pop Rivets
Pull Off Sail Panel
Grab the door pull in the arm rest and tug it towards yourself to disengage the pop rivet friction fasteners that hold the panel to the door frame.Move to the top corner of the door panel and pry off the triangular "sail" panel. On some vehicles, the sail panel contains the tweeter speaker.
Lift Panel Off Door Lock
Pull Out Door Pull Cable
Lift the door panel off the door lock button and tilt the top of it out towards yourself.Use a pair of needle nose pliers to gently lift the metal ball at the end of the door opener cable out of the mechanism.
Disconnect the door cable from the back side of the door panel.
Door Pull Cable Removed
Disconnect Power Mirror
Then disconnect the power connector for the side view mirror by lifting up on the release tab. Slide the power connector off the plastic anchor on the metal door frame.
Slide Connector Off Anchor
Unlock Connector
Connector Detached
Look behind the door panel and locate the large wire connector with the pink lever lock. Swing the lever open to unlock the connector and separate it from the socket.
Door Panel Removed
Power Window Motor
10mm Bolts
Now the door panel can be completely removed by lifting it up and off the door frame.To replace the power window motor, remove the 10mm bolts.
Stock OEM Door Speaker
Remove 7mm *****
The stock "OEM" speaker is held in place by a single 7 mm *****. Remove it with a socket and ratcheting wrench.
Pry Off OEM Speaker
Speaker Removed
Disconnect Power Plug
If the speaker is stuck to the door frame, gently pry it off with a small flathead screwdriver.Disconnect the speaker's power plug by pressing the release tab with the small flathead screwdriver.
Fits 5.25", 6.5", 6.75"
Re-installing Door Panel
According to the Crutchfield website, the 2008 to 2012 Chevrolet Malibu's front door speakers can be replaced withaftermarket speakers in the following sizes: 5 1/4", 6 1/2" or 6 3/4" speakers with the use of a bracket.If you'd like to reduce road noise, make your car quieter and also improve the sound from your speakers, I'd recommend applying some Dynamat Sound Deadener on to the metal door frame.
Re-Attach To Anchor
Plug In Power Side View Mirror
Re-Insert Power Connector
To re-install the door panel, first hold the panel close to the door frame before re-connecting the large wire plug. Swing the pink lever closed to lock it in place.Slide the socket for the power side view mirror back on to its anchor and insert the power plug.
Lock Power Connector
Pink Lever Locked
Re-Insert Door Pull Cable Ball
Insert the metal ball at the end of the door opener cable back in to the door handle mechanism.Slide the black plastic cone part of the cable back into the slot in the door opener assembly.
Door Opener Cable Reinstalled
Hang Door Panel On Frame
Gently lower the door panel down on to the edge of the door frame with the door lock switch through the opening at the top.
Line Up White Plastic Fasteners
Push On Sail Panel
Push Door Panel In Place
Move to the bottom of the door panel and line up the white plastic pop rivet fasteners with the holes in the metal door frame.Push all around the door panel to re-insert the pop rivet fasteners.
Re-attach the sail panel at the top corner of the door frame.
Push Panel Flush Against Frame
Insert Side Edge Fasteners
Insert Larger Piece First
Next move to the side edge of the door panel and first re-insert the larger piece of the two fasteners. Then insert the smaller "pin" piece of the fastener into the middle of the larger piece.
Insert Small "Pin" Piece
Install Lower Edge Fastener
Tighten 2 T25 Torx Screws
Re-Attach Power Connector
Insert Front Hook First
Insert and tighten the two Torx T-25 screws located under the arm rest.Re-attach the power connector to the plastic arm rest panel.
First insert the hook at the front of the arm rest panel and then snap the rear end in place.
Pop Arm Rest Panel In Place
Tighten 2 T25 Screws
Replace Rubber Cover
Insert and tighten the two T25 Torx screws into the door pull cup. Then replace the rubber cover over the two screws.
Tighten 10mm Door Handle *****
Replace Door Handle Trim Plate
Malibu Door Panel Replaced
Replace the 10mm ***** that goes above and behind the door opener handle and tighten it. Pop in the plastic trim plate behind the door handle.
Apr 10, 2016 | Buick Cars & Trucks
How do I refit the rubber strip on bottom edge of front bumper that's come adrift ?
Due to the age of the vehicle and the fact that these type of situations usually happen due to physical damage. I would look to a pop riveter with backing washers and a good adhesive, Simply glue it in place, after cleaning both pieces with a solvent such as paint thinner, use tape to hold it in place and then drill it and pop rivet it using backing washers front and back at equal distances for further mechanical strength. Do both ends then the middle and then the middle of those open spaces that are left, depending on the width of the rubber strip you may have to do this again with the remaining undivided spaces.
Jul 22, 2014 | Vehicle Parts & Accessories
Tail light replacement Removing Lens Cover
Just use a Torx wrench. I can't remember if it's a size 15 or 20, but it's pretty easy. Look closely for the Torx screws. I believe you have to open the tailgate to see them.
As stated above, the inside edge of each light has two Torx screws, but there are also two plastic "pop-rivet(?)" type connectors along the outside edges that come loose with a gentle **** away from the vehicle.
Dec 26, 2010 | 2004 Jeep Liberty
How do you replace the Driver's side power window motor on a 2001 chevy caalier
Before replacing the motor I recommend that you verify that the switch is functioning properly. Replacing the switch is considerably easier than replacing a window motor.
Here is a description of what to do to replace the electric motor in the driver's power window on a Chevrolet Cavalier.
1. Remove the interior door panel. There are two screws in the arm rest and four around the sides and bottom of the panel. Disconnect the window door lock cable from the switch on the door.
2. Remove the sound system speaker by first disconnecting the electrical cable and then removing four screws.
3. Remove the plastic water shield. The shield is held in place with an adhesive that behaves like bubble gum. Pulling the plastic shield away from the door causes the adhesive to become stringy like bubble gum. The nice feature of this is that some adhesive adheres to the door and some to the shield so that during reassembly the shield sticks well to the door. During removal use a razor blade to cut the strings to help reduce any mess. Some of the shield was caught under the door panel armrest support so that it was necessary to cut the shield to completely. Rather than cutting the shield just folded it up and taped it to the door. Be careful of what comes in contact with the adhesive because after a few hours of contact the adhesive sticks to almost anything. It even stuck to the wax paper placed over the adhesive to keep it from attaching to anything it came in contact with while removing the window regulator/motor assembly.
4. Remove the window glass. There are two nuts holding the window glass to the window regulator. It is easiest to have the window positioned about half way up to allow access to the two nuts. The window glass can be pulled out of the door by lifting the rear edge of the glass first.
5. Disconnect the electrical connector from the window motor.
6. Remove the window regulator and motor assembly. This will require an electric drill and some drill bits to drill out the 5 rivets. There are two bolts that attach part of the window regulator to the door. These need to be removed as well. Once the rivets and bolts have been removed the entire assembly (window regulator and motor) can be removed through the large opening near the rear of the door. It may not look like it will fit, but it does. The most difficult part of this repair was locating rivets to replace the rivets that are removed. Be careful to find replacement rivets that are the same length as those that were removed because at least two of the rivets could interfere with the moving parts of the window regulator if they are too long.
7. Remove the window regulator from the motor. There are three rivets that hold the window regulator and the motor assemblies together. Remove the rivets by drilling them out. These rivets can be replaced with screws from the local hardware store if you prefer not to use rivets.
8. Attach the new motor to the window regulator assembly using rivets or screws. Use stainless steel machine screws and nuts along with a lock washer under each nut. Choose whatever attachment method you prefer.
9. Lubricate the window regulator with white lithium grease.
10. Reinstall the window regulator/motor assembly in the door.
11. Plug the electrical connector back on the window motor.
12. Reinstall the window glass. Insert the front edge first to make this easier. Reinstall the two bolts holding the glass to the window regulator.
13. Test the new motor by opening and closing the window to ensure that it is operating properly. If not, resolve the problem and continue.
14. Reinstall the plastic water shield.
15. Reconnect any electrical connections.
16. Reinstall the sound system speaker.
17. Reinstall the interior door panel. Remember to reconnect the power lock connector.
The job is complete.
Nov 24, 2010 | 2001 Chevrolet Cavalier
How to replace exterior door handle on the back passenger side. What tool is needed?
there are two rivets that you will have to drill out. on the inside of the door, there is a threaded clip that holds the linkage in, you will have to open it (it opens like a door, it may be a little stubborn, but it will open). then put your new handle on, and then the linkage back in, and snap the clip back in place. you will need one of the bigger pop rivet guns because the rivets are 1/4 ones. also, when you go to rivet the handle back on, tape some cardboard under the handle. that way if the rivet gun drops after it snaps off the rivet, it will not scratch the door. hope this helps you.
Oct 14, 2009 | 2000 Ford Explorer
1989 Ford F150 power window
you have to disconnect the negative side of the battery so you won't kill it then remove the door panel look for hidden screws behind the arm rest and behind what looks like little doors that you have to use a screw driver to open once that is removed you will find a plastic sheet just cut and peel this back (you can use duct tape to replace it when you are done) also put on gloves because inside the doors there is sharp edges, you then can see the motor and you will need to break off the rivets but you can put the new one on with just a small bolt and nut and use lock tight
Jan 05, 2009 | 1989 Ford F 150
U joint replacement 94 chevy cavalier
If your talking about the lower ball joint , the OEM ball joint is riveted on with three rivets, the replacement is bolted on with three bolts/nuts. Carefully drill out these rivets (try not to elongate the mounting holes) . Drill the heads off and use a pin punch to remove the rivets. Pull off the old ball joint and install new with attaching hardware (which should be provided in kit). I can't remember the torque values, any shop should be able to provide this but I think it's 50 ft. lbs.
Ckeck alingment
Jan 04, 2009 | 1994 Chevrolet Cavalier
1998 Chevrolet mailbu window motor replacement
they are very tricki even good experience mechanics have hard time some time to do it, just try to look for any bolts or screws arrown and remove it, or they have like snap in plastic rivets arrown the edges for the panel, insert a flat screw driver from the edges and pry a little to pop out the rivets
May 28, 2008 | 1985 Chevrolet S-10 Blazer
Upgrading Memory on Packard Bell MIT GHA20
If you look along the top edge of the escape/function/del keys, there are several small plastic tabs that hold the keypad in place. Use a very small flat head screwdriver to push these back from one corner across to the other, gently lifting the keypad as you go. When you press back the last tab, the keypad should just pop out but take care as it's connected by a cable at the bottom edge of the keys. The RAM slots are located under a thin metal cover under the keypad. You'll need a very small philips head screwdriver to undo this. After installing RAM, replace the metal cover then pop the keypad back in, bottom edge first and just press down the top edge and the plastic tabs should snap back into place. Hope this helps!
Mar 08, 2008 | Computers & Internet
Sparks are flying
This needs to be corrrected. The job of the waveguide cover is to protect the waveguide (opening) and the magnetron from buildup of food particles and grease. When the grease and food particles build up on and behind the cover, they will carbonize and arc - and maybe even flame up! The solution is to clean it and keep it clean - but if it's too dirty or is burned, it must be replaced. Sometimes it's necessary to remove the cover to clean both sides of it, and to clean the edges of the opening it covers. It is sometimes held in place with a small plastic rivet (or screw) and once that is removed, the cover will slide over a little then drop down. Be VERY careful not to get cut on the potentially sharp edges of the opening, and do not spray anything into the opening. Apply an alcohol-based cleaner (such as the purple kind) and /or gentle scouring powder to a cloth or paper towel and carefully wipe it out, then when it's dry, reinstall the cover and the rivet. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Even better, we have the full service manual in PDF format available for download at http://207.234.249.73/mwd/r930ak_aw_sm.pdf It will guide you through the safety issues and give you exploded views and part numbers in case you need to order parts, which you can get at Tritronics at http://www.wehaveparts.com
May 12, 2007 | Sharp R-930AK Convection/Microwave Oven
Dell PowerEdge 830  Server Logo
266 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
