Question about KitchenAid Dishwashers
We have a film on the dishes after they have washed. How can I get rid of this? Also, the pocket on the door that holds the dishwashing detergent does not open all of the time. Thanks
  • 4,323 Answers
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Posted on Jan 01, 2011
Dishwasher leaves a white film on didhes and film will not come off.I have drained water heater for about 20 mins to remove calcium deposits but problem still exists.
Start a wash cycle with no dishes and no soap.
Once the machine fills with water and starts washing,open the door and pour in one quart of WHITE vinegar and resume the wash cycle.
Change your dishwasher detergent to the ELECTROLUX brand.
It has added chemicals to combat the problem you describe.
The government mandate to remove phosphates from dishwasher and laundry detergent has resulted in unclean appearance of dishes and laundry.
Apr 05, 2011 | GE Dishwashers
Dryer is running, but rotating very slowly. it generates heat, but makes a very loud noise. it's a GE Adora Dryer
Instructions
1. Wait approximately 90 seconds for the light to turn off if the "Start/Reset" indicator light flashes. Press the "Start/Reset" button to restart the wash cycle.
2. Close the dishwasher door and move the latch to the locked position if you hear a beep once every 30 seconds when the dishwasher should be operating. The dishwasher will not operate if the door is open.
3. Turn on the hot water faucet and feel the water to check if it is hot. Wait for the water to warm up before running the dishwasher if the water is not hot. Check that you have proper water pressure and wait for the pressure to return to normal if it is low. Your dishes may not come out clean if the water is not the correct temperature or if you have low water pressure.
4. Move the dishes on the racks so that they do not block the detergent dispenser or washer arms on the bottom of the machine. The dishes will not come out clean if they block the detergent dispenser or the washer arms.
5. Load the proper amount of detergent in the dishwasher if you find spots or film form on your glasses. If you have hard water, use a rinsing product such as Jet-Dry in the dishwasher to clean the spots or film. If the problem persists, wash smaller loads of dishes.
6. Add only automatic dishwasher detergent to the dishwasher if you find excessive suds in the tub after running a cycle. Measure out the proper amount of detergent.
7. Press the "Heated Dry," "Hot Start," "Hot Wash" and "Added Heat" buttons, if you find that your dishes are not fully dry after a wash cycle completes.
8. Press and hold the "Heated Dry" button on the dishwasher for approximately three seconds if the control pad does not respond to button presses. This is the child lock that prevents unwanted use of the dishwasher.
Feb 24, 2011 | GE Dryers
Kenmore Ultra Wash dishwasher leaves spots on ALL dishes, top and bottom. Changed detergent, same problem.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 24, 2011 | Kenmore Dishwashers
I have a model GU2300XTVQ Lately we have fine brown residue on the bottom and door of the unit whenit finishes washing. The dishes seem clean. Is there a filter or something we need to clean?
heatman101
Feb 07, 2011 | Whirlpool GU2300XTVQ Builtin Dishwasher
Both dish drawers are leaving a chalky dried on residue on the dishes. I ran a cleaning detergent in both drawers, made sure salt in water softener was filled, checked filters, and they are still leaving...
heatman101
Oct 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
heatman101
l'l
Sep 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Even after a wash-a white detergent residue is left.
I have a Whirlpool Gold dishwasher and had the same trouble. I found the solution. Fill the detergent dispenser to the top with Cascade Complete liquid gel - it is in a green bottle, then put a half a cup of white vinegar in the bottom of the tub before you start the dishwasher. I have tried them all and Cascade Complete Gel works best. Don't use powder. It really builds-up on my dishes and only the gel keeps the film off my dishes.
I also add Jet Dry in the rinse-aid dispenser but I have a friend who use vinegar in that too. The dishes come out sparkling clean with no film or white build-up. If they still are filmy after three washes using this method, then you may have some build-up in the dishwasher and you can put a cup or two of white vinegar in the bottom - with no detergent or dishes and wash and rinse well. That helps get rid of build-up.
Apr 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Mar 18, 2010 | Kenmore 16764 Dishwasher
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
56 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
