Error code dE - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
DE = Door Error
Is this a "LG" washer? If so, look at this link.
Posted on Jan 01, 2011
Como puedo aser para k se apage el chek trans de mi isuzu trooper 93
Check transmission lamp? my Isuzu trooper Apage 93 And disconnected plug, and even blinks stills
the lamp means transmission errors.
IS this car an automatic transmission.?
if yes, then some flash the OD lamp and others blink a check transmission warning lamp.
we find the car has TCM ? transmission brain and we scan it.
this old car has flash codes for TCM.
we insert the jump to the TCM DLC connector and it flashes out error codes, we write down and use to fix car.
translated
Compruebe la l?mpara de la transmisi?n? mi soldado Isuzu apage 93 Y enchufe desconectado, e incluso parpadea alambiques
la l?mpara significa errores de transmisi?n.
Este es un coche de una transmisi?n autom?tica.?
en caso afirmativo, a continuaci?n, algunos de flash El indicador OD y otros parpadear una luz de aviso de transmisi?n cheque.
Podemos encontrar el coche tiene TCM? cerebro de transmisi?n y escanearlo.
este viejo coche tiene c?digos de flash para TCM.
insertamos el salto al conector DLC TCM y destellos a cabo los c?digos de error, escribimos y usamos para fijar coche.
Oct 12, 2015 | Isuzu Cars & Trucks
Sc 536 error code
Ol? tudo bem! o erro funcional (SC 536) trata-se de um cooler ou do sensor de temperatura que parou de funcionar levando o sistema a parar de funcionar por medida de seguran?a, infelizmente trata-se de um daqueles problemas que s? a autorizada resolve.
Jan 14, 2013 | Ricoh Toner for Aficio 1060, 1075, 2051,...
De error code
DE is a drain error
Check to be sure the drain filter is clear.
Nov 30, 2012 | LG WM-2277HW Front Load Washer
What is the code " de" for?
I'm going to assume you meant DL error code because there is no DE error code for this model, If you have anymore questions please feel freeto ask, Rich
Jan 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Canon IR1510 error E000
there is a problem in the fixing assembly something to do with the thermoswitch if i am not mistaken without the full error code it is hard to say exactly what is wrong with it
Jun 10, 2010 | Canon imageRUNNER 2000 Copier
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Getting error 0xc18a0206
Aquí es el contenido de la charla, espero que te ayuda también! Christina es la persona de soporte técnico.
Cristina: Vamos a realizar algunos pasos para aislar el problema y encontrar una solución para ello.
Christina: Por favor siga los siguientes pasos y que me haga saber el mensaje que se mostrará en la impresora.
Christina: A. - Mantenga pulsado el "*" tecla.
B. - Presione la tecla "#" y suelte ambas teclas.
La pantalla debe decir "Intro Especial clave Combo"
C. - Presione y suelte en la secuencia de "1", "2" y "3" botones.
CustomerName: ok
CustomerName: pantalla dice "apoyar" R0631M
Christina: Fine.
Christina: 2. Oprima y suelte el botón de flecha derecha hasta que la pantalla dice "Menú de configuración del sistema".
Christina: 3. Oprima y suelte el botón "Aceptar".
Christina: 4. La pantalla debe decir "estado de error de hardware". Si no existe ya, tecla de flecha a "estado de error de hardware",
Christina: 5. Oprima y suelte el botón "Aceptar".
Christina: 6. La pantalla debe decir "estado de error de hardware: Despejado. Pulse OK para borrar ".
CustomerName: yup
Christina: 7. Oprima y suelte el botón "Aceptar". Mensaje a los cambios "estado de error de hardware Resueltos. Pulse Cancelar para continuar ".
CustomerName: ok
Christina: 8. Pulse y suelte el botón "Cancelar" tantas veces como sea necesario, de modo que, o bien el "Bienvenido a Photosmart Express" aparece la pantalla, o, el "fallo del sistema de tinta" aparece la pantalla. POR FAVOR, NO intente imprimir en esta etapa.
CustomerName: ok
Christina: 9. Utilizando el botón de encendido, apague la unidad y desenchufe el cable de alimentación de la parte posterior de la impresora y la pared.
CustomerName: hacer
Christina: Fine.
Christina: 10. Espere 30 segundos para obtener el poder de vertido y, a continuación, enchufe el cable en la toma de corriente y, a continuación, en la parte posterior de la impresora
CustomerName: hacer
Christina: 11. Encender la unidad. La impresora puede mostrar mensaje "BOTóN PARA PODER UTILIZAR LA IMPRESORA SHUTDOWN" seguido de "Pulse OK para continuar". Pulse Aceptar. La impresora comenzará la "TEMNE UNA TINTA proceso de inicialización". Permitir que este proceso para completar y no interrumpir. Una vez que el proceso de inicialización se ha completado, la impresora imprimirá una página de diagnóstico.
CustomerName: hizo una buncha ruido, y no imprimir una página de diagnóstico
Christina: Bueno.
Christina: ¿Es todavía el mensaje de error que se muestra en la impresora?
CustomerName: No
Christina: Bueno.
CustomerName: debo intentar imprimir algo?
Cristina: Vamos a imprimir una página de prueba libre, para comprobar la funcionalidad de la impresora.
Christina: Pulse sobre el menú de configuración "todo en uno" luego desplazarse utilizando la tecla de flecha y seleccione la opción Imprimir a continuación, seleccione Informe de Autoevaluación Informe de ensayo.
Oct 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Error code E02B05
Error Code E02D02 = Clean de coding tape behind the rubber belt.
Error Code E02B05 = Problem with de ink cartridge door.
Oct 23, 2007 | Canon imagePROGRAF W8200 InkJet Printer
Error code de
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
Mar 29, 2007 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
