Question about ASUS K40IN Notebook
The laptop has a built in camera. My picture is inverted. How do I fix this problem
    Sergeant:
  • 223 Answers
Hi lilly, i am happy to assist you, just follow the steps.
To check the Webcam issue, go to http://www.cameroid.com/ and see if your picture is upside down.
If your picture is upside down, then that means that a setting for your webcam could be wrong. (You might find your webcam control software either under Control Panel, or in "All Programs" under the manufacturer's folder.) To fix this, launch your webacm configuration program and click Properties, look around the program [the option MAY be hidden in an ADVANCED tab,] and make sure that there isn't some option checked that says something like "flip video".
If your picture **ISN'T** upside down (from Cameroid.com,) then that means your camera is working properly, and that your VIDEO PLAYER is flipping the video on playback. Launch your video player, and click Properties. Look for a "Flip Video"-like entry and make sure it is turned off.
Posted on Jan 01, 2011
Computer will turn on but the screen stays black , how do i fix it ?
Hook a spare monitor to the video output usually on the back, if picture okay it is the inverter board just below the screen, or the backlight behind the display, but if both show the same symptoms it is the video graphics chip built into the motherboard.
Jun 19, 2012 | Computers & Internet
Acer Aspire Black Screen
You are describing too different types of problems, difficulty in seeing the screen and now it is gone black. The LCD screen will need to be replaced, I'am hoping the built in display light has failed and not the inverter board because you could end up changing the screen and the inverter board adding to the expence. Go to www.ebay.com type make and model of laptop, refine search to screen and inverterboard.
Jun 01, 2012 | Computers & Internet
My screen is blank gateway ms2285 can u help me fix it
Hook a apare monitor to the video output usually on the back, if picture okay! the problem is the inverter board "below the LCD screen" or the backlight behind the LCD display. But if symptoms are the same, the video graphics card is the issue normally built into the motherboard.
Mar 26, 2012 | Gateway NV5378u Notebook
Ihave an hp pavillion laptop where the screen went black and need a solution to fix
First hook a spare monitor to the video output jack usually on the back, if picture comes up! it indicates a bad inverter board, or the backlight has stopped working, if the spare shows the same problem, it means the video graphics card is defective and normally built into the motherboard.
Mar 05, 2012 | HP Computers & Internet
My built-in camera the image is up-side-down.
Change the Camera Settings:
There is usually a checkbox for "Invert Image" or "Mirror Vertical." Un-check this box if one exists. If you can't find this checkbox, try searching the other tabs.
Jul 18, 2011 | Computers & Internet
My webcam has gone upside down but its built in one so how to fix it ?
This can be resolved either through the software you are using (ie. Yahoo Messenger) or through the webcam's driver software. Here is an example with Yahoo:
Click Messenger and select My Webcam Click File, then Preferences and choose Webcam. Click on Camera Settings, then look for something that says "Mirror Vertical" or "Invert". That's what you want to change.
Jan 22, 2011 | Computers & Internet
How do i take a picture on my Toshiba laptop
1. Open a program called"Camera Assistant." This is a Toshiba-supported computr program designed specifically for people with cameras built into their laptops.You can find this by clicking on the "Start" menu and then navigatingto the "Programs" sub-menu. 2. Press the"Picture" button in the "Camera Assistant" program windowto take a picture using your built-in camera. This will take one stillphotograph for every time you click the button. The image you are taking willappear on the right side of the main program window. 3. Press the"Video" button in the "Camera Asst" program window tobegin recording video using your built-in camera. This will record video untilyou press the "Stop" button. The video you are recording will appearon the right side of the main program window. 4. If you can't open"Camera Assistant," reinstall your drivers. Though the camera on aToshiba laptop is designed to work right out of the box, if it doesn't you mayneed to reinstall the driver that makes it work. Look for the CD labeled"Drivers and Software" that came packaged into the box with yourToshiba laptop. Pop it in your laptop's CD-ROM or DVD-ROM drive and install the"Digital Camera" driver contained on the disc.
Nov 11, 2010 | Toshiba Satellite A105 Notebook
Black screen after startup
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 05, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
I have a Gateway 4530GZ laptop that has no backlight. the screen went black about one week after the warranty expired and of course gateway wanted me to jump thru hoops and pay a fortune to see IF it could...
The inverter in this particular laptop is in the LCD screen itself. It's at the bottom, in the center. It's rather difficult to judge when looking at pictures online as they are usually way bigger than the piece actually is. Anyways, if you need pictures of where the inverter is, just let me know, I have this same laptop torn apart as well. Unfortunately for me the inverter was not the problem. On to the bulb now.
Feb 21, 2009 | Gateway 450ROG Notebook
Inverted picture on yahoo messenger
under c:\windows\bisoncam there is a program that will allow u to change this.
Nov 26, 2008 | Computers & Internet
ASUS K40IN Notebook Logo
649 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
