Question about Whirlpool WED5200T Electric Dryer
On my electric dryer, the heating element comes on but the dryer will not start when I push the button. Before it quit working, it came on and it only heated on very high heat, even in the "fluff" mode. The belt is on there and is in good shape.
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Mai
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
When pushing the start button the dryer will come on for about 10 minutes and then stop. Then sometimes it doesnt come on at all
If it starts right back up after stopping there is an electrical problem maybe at the motor start switch. If you have to wait for an hour before it will start again then the problem might be that the motor needs to be cleaned of a lint build up.
Oct 23, 2012 | Roper RES7646KQ Electric Dryer
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
80 series front load dryer will not turn.
It almost has to be the belt as the heating element won't come on without the motor turning.
Jun 26, 2008 | Kenmore 62802 Electric Dryer
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Dryer Won't Start
most common problem with the dryers is blown thermal fuses, something gets too hot and for safety reasons the thermal fuse blows. You can also check your incoming power supply make sure the breakers havent tripped. part num( LA-1053 )about $30 comes with directions to install. its located under main top towards the rear of unit moundted to the side of heater.BE SURE TO TURN OFF ALL POWER BEFORE CHECKING ITS LIVE!!!!!!!!!
Mar 06, 2008 | Maytag PYE2300AY Electric Dryer
Not heating
It is probably a thermal fuse. Take off the back of the dryer and you will see it on the lint outlet tube. It is white and is 1/2 inches wide and 2 inches long. It has two leads coming out hooked to wires. To check it just pull one of the leads off, turn on the dryer and touch the wire you took off to the other one and the burner should come on. It costs $12 at a parts store.
Jan 31, 2008 | Roper RES7646KQ Electric Dryer
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool WED5200T Electric Dryer Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
