Question about Mitsubishi WD 65837 TV
I have a wd-52531 tv which the pictureis pretty dim. I have replace the lamp about 3 months ago and it not solve the problem. I just cleaned te mirrors yesterday and it did not help. Is there anything else i should be looking at to solve this? I have not looked at the boards or the caps. Thanks Jim
    Brigadier General:
  • 8,909 Answers
You may find the lenses are dirty but cleaning them is very specialized. It may bring the light engine back up to a reasonable level again.
Posted on Jan 01, 2011
Bad Lamp for TV
Can't get a reception with my ws-a55 tv
Feb 15, 2014 | Mitsubishi WS-55809 55" Rear Projection...
The lamp light is blinking orange and we just replaced the lamp! on model WD-52531
You may have not plugged the lamp in fully or have not put the lamp door back properly. If you have done this properly and have the blinking problem then you are likely to have a bad ballast. This ballast supplies the voltage to light up the lamp. But first look on the front of the set for a small push button that says "system restore/reset". Use a ball point pen to press.
Jun 28, 2011 | Mitsubishi WD-52531 Television
Mitsubishi WD-52531 not working after replacing the buld.
Check to make sure the lamp is in correctly and that you've closed everything up properly. If you don't close the cover, the sensors will tell the computer in the TV that the door is open and won't let the TV turn on.
Other than that, could be a bad lamp or bad ballast.
Always buy OEM lamps, or better-than-oem equivalents! Philips lighting is the best lamp manufacturer out there for these TVs. They invented the thing!
Buy from Authorized distributors, and don't buy the "cheap" stuff. savnig 20 bucks will cost you more in the long run--believe me!
Feb 05, 2010 | Mitsubishi WD-52531 Television
Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Jul 18, 2009 | Mitsubishi WD-52531 Television
Same problem with Mits WD-52531
The first thing to try is to reclose the access door to the lamp area. There are interlocks there that may be marginally connected. Try to reclose all access doors and report the results here.
Thanks,
Dan
Jun 29, 2009 | Mitsubishi WD-52531 Television
Wd-52531 has sound, then clicks off after few seconds
It can be the lamp. But the color wheel and ballast can cause the same thing. Put your ear to the back of the set when you push the power button and you should can here the color wheel start up. If not, that is your problem.
Now if the lamp is not lighting up. you should here a ticking sound from the back of the set, if not the ballast is bad. If the lamp is coming on and then going out after only about 5 seconds AND you do not here the start up of the color wheel, the color wheel is confeirmed bad.
Nov 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Lamp failed 2x in 4 months..is it the Lamp?
do you get an error code? hold the MENU and DEVICE buttons when turning on the TV and get error code
Oct 20, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 65837 TV Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
