Got message engine fusion low heat error I replaced the fusion unit in early 2010, do I need to replace it again?
  • 4,338 Answers
Low heat means the the fuser is not reaching operating temperature. The fuser may be bad, it could also mean that your voltages from the power supply are low. But , yes it is probably the fuser. The one you replaced in 2010, should have warranty, depending on where you purchased it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Posted on Jan 01, 2011
2009 fusion SEL has data compass error after being rear ended and a shop did repair.
WHAT IS A COMPASS ERROR FOR A 2009 FORD FUSION ...
www.fixya.com/cars/t16705785-compass_error_2009_ford_fusion
Feb 21, 2013 - WHAT IS A COMPASS ERROR FOR A 2009 FORD FUSION A MESSAGE COMES UP ON MY DASH SAYS COMPASS NO ... SOURCE: I HAVE A2009 FORD FUSION AND IT'S NOT GOING OVER 20 MPH ... Compass data error -- how do i determine my zone-- ... Jan 28, 2010 ' 2007 Ford Edge SEL Plus.
Compass - Ford Fusion Sport - Ford Fusion Forum
www.fordfusionforum.com/topic/9390-compass/
Jan 23, 2013 - Compass - posted in Ford Fusion Sport: 2011 Fusion SEL without navigation screen. Following windshield ... I have recalibrated and reset the compassaccording to the manual instructions (several times) but cannot correct the error. Can anyone help? ... picture of where it is: 2009-08-30_051718_2.gif.
Nov 08, 2015 | 2009 Ford Fusion
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
What does a po130 code on 2010 Ford Fusion Hybrid mean?
Possible causes
- Faulty Front Heated Oxygen Sensor Bank 1
- Front Heated Oxygen Sensor Bank 1 harness is open or shorted
- Front Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks
Tech notes
Replacing the O2 Sensor 1 usually takes care of the problem
Jul 27, 2014 | 2010 Ford Fusion Hybrid
2010 Impala turn a/c off engIne hot
You need professional help
Have a local shop resolve
Jul 01, 2013 | 2010 Chevrolet Impala LT
My samsung CLX 2160 giving me Low heat cycle power error
To clear the "low heat" error, turn the machine off and unplug it from the wall. Wait a couple seconds then plug it back in and turn it on. Hopefully the error will clear and you can resume normal operation.
If the error still occurs, you'll have to call a service technician to either fix or replace your printer's fusing unit.
Aug 21, 2010 | Samsung SCX 4521F All-In-One Laser Printer
I bought a Samsung CLX 2160 laser color printer about 2 years ago and since some weeks I get an error message '' low heat'', no printing is possible since then. where is the problem and how can I solve it?...
The "low heat" error indicates a problem with the printer's fusing unit. Turn the machine off, unplug it from the wall, then plug it back in and turn it on. If the error shows up again, you'll need to call a service technician to come out and either repair or replace the fusing unit.
Jun 16, 2010 | Samsung CLX2160 Multifunction Color Laser...
Low heat error
the fuser is defective and needs to be replaced.
Jun 11, 2009 | Samsung CLP-600N Laser Printer
Okidata c5200n printer 173:FATAL ERROR. What is this? How do I fix it?
In the fuser unit the Heat roller thermister indicates a low temperature error. Replacing the fuser unit will usually resolve this. Fuser units are consumable items bur for an early life failure such as this it may be worth contacting the manufacturer.
Mar 11, 2009 | OKI C5200n Laser Printer
136 people viewed this question
k24674
