Question about KitchenAid KUDS40CVSS Builtin Dishwasher
When we do not use the dishwasher for a week or more water seems to back up into the tub. The water has a foul smell to it and can be as much as an inch or so deep. The dishwasher drain hose is attached to an insinkerator disposal. By the way this dishwasher is only a couple of months old and we have had to have it serviced three times. No one has been able to explain the water accumulation and it can not be demonstrated unless the washer sits unused for a while.
    Top Expert:
  • KitchenAid Master
  • 24,742 Answers
Sounds like a blockage in the waste pipe under the sink.
Posted on Jun 10, 2017
5 Suggested Answers
  • 784 Answers
SOURCE: dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Posted on Sep 13, 2009
  • 1382 Answers
SOURCE: DIshwasher doesn't drain. 3-4 inches of water sits in the bottom.
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Posted on Sep 25, 2009
  • 43501 Answers
SOURCE: My dishwasher smells after use
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
Posted on Sep 29, 2010
  • 43501 Answers
SOURCE: Water does not completely drain? Garbage disposal
Posted on Jan 03, 2011
Should there be standing water in the pump/filter in not used for 8 hours +
the question is? is there standing water in ur tub if so then check ur water inlet valve
Mar 17, 2015 | Washing Machines
Why is there a foul smell in the dishwasher?
You might want to check the drain hose. It should be mounted up, or have a loop that is higher that the garbage-disposal port that it feeds into. If it is not mounted up, or have a high-loop, it is possible that water from the sink and debris from the garbage disposal can backwash into the dishwasher, and that would be the cause of the smell. Alternatively, it is possible that the heater is not working at all, so dishes aren't drying, and the water isn't getting hot enough to kill the bacteria, mold, and mildew that can form if the water isn't getting heated during the wash cycle.
Sep 14, 2014 | Dishwashers
Ther's a foul smell coming from the dishwasher evert time I open it. Doing a wash does not solve this. I'v had this since it was new, months ago, and have had the installer look at it, said it wasn't his...
You need to run a cycle with a dishwasher cleaner inside, you can get these from the same place you get your dishwasher powder from, Before you run the cleaner through remove the filters from the bottom of the machine and place these in the rack, run through the hottest cycle with these filters in the racks and the dishwasher cleaner in place, this will clean the dishwasher properly and assist with correct draining and the odour, if the dishwasher is sitting for long periods unused leave the door open slightly to allow it to dry out.
May 13, 2017 | Frigidaire FGHD2433K 24 in Builtin...
Our 2 month old Frigidaire FGHD2433KF1 dishwasher is producing a very strong foul odor. It is not connected to a garbage disposal and we only see a small amount of water in the bottom of tub when the...
Do you have it connected to an air gap? If not this can allow the water to drain back into the dishwasher and will sometimes have food particles in it making it stink.
Oct 23, 2010 | Dishwashers
The dishwasher is not cleaning properly, glasses look like they have a film on them, plates also do not look clean & the dishwasher has a foul smell.. like rotting food in it.. we use the top quality...
Check the main drain system connected to the dish washer hose pipe. Clean the junction if clogged. This smell might orginate from the pipe.
Check incoming water quality. If hard water is noticed, use softener attachments to the inlet.
Fill dish washer salt in the dispenser. Refer user guide. The salt will help softening the water to certain extent. Finally check whether rinse aid dispenser filled with the rinse aid liquid.
Jun 01, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Foul odor from front load washing machine
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Nov 06, 2009 | Washing Machines
Backup of foul smelling water into the dishwasher
Outlet pipe is partially or completely blocked.
Use a dishwasher cleaner in it, but before you even do that, remove outlet pipe from waste pipe - and clear all the gunk out you can.
I suggest a bucket with disinfectant and washing powder to dissolve the grease.
You may need a drain cleaner down the waste pipe too - & flush with hot water and washing powder.
Aug 04, 2009 | GE Profile PDW8400J Built-in Dishwasher
Foul odor
first hting do you use a rinse agent( jet dry ?) perhaps s you're not selecting heated dry as an far as the smell if its musty form water left behind,using jet dry will evaporate more of the water (a small amount on a paper towel and wipe down the inner door and walls will also decrease moisture, doenst to be done every time either on ly as needed might be once a year. if the smell is anything else id look into perhaps hoked to a garbage disposer?? smells permeate back into d/w.
Mar 10, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Kenmore Ultra Wash Model 665 Dishwasher
Dishwashers which are properly installed and regularly used won't normally have a problem with bad odors. Check the following: ?Was the drain hose brought in at the top of the cabinet, or down near the floor? it must be 34" from the floor. ?Do you run the unit at least once every 2 days? -Run a cycle with a quart of vinegar to clean the tub and pump. ?Does the disposal tend to back up slightly when the dishwasher drains? Drain may be clogged. -Don't use gel detergent! ?Check your water softener(If so equipped) These can cause foul odors in the water supply if not properly balanced or maintained Good luck!
Sep 02, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Water smelling
Although it might not be the most ecological solution, you might add a small amount of bleach to the container, once a week (let it act for some hours before you use the washing machine again - at night for example). I'm pretty sure it will help! Good luck!
Dec 06, 2006 | AEG Lavamat W1050 Front Load Washer
KitchenAid KUDS40CVSS Builtin Dishwasher Logo
37 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
