Computers & Internet Logo
Posted on Jul 08, 2008
Windows xp home
Can't down load windows fixes...Genuine windows validation keeps telling me that my windows is not valid.. But it is.. I have a Dell e510 that came with xp (home) I notice that the info for the registration is missing in my computer..I have tryed all of Microsofts fixes But doesn't seem to work thanks for looking
  • poppyjim2 Jul 09, 2008
    Nothing worked there OneRob but thanks a lot for trying
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 08, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
971
Points
12
Poppyjim2,
Try following this link http://www.softwaretipsandtricks.com/forum/windows-xp/23046-windows-validation-trick.html
Remember, the instructions listed at this link are for testing purposes only..
Hope this helps!
2answers
My window copy did not pass genuine window validation .
if that the case, its either yo don't have the original serial key for your windows xp. if ever that is, go and reinstall your xp and try to download a program for the validation of your xp. it will bypass the authentication security and your xp will be authenticated.
I keep getting message saying that my Windows did not pass the genuine Windows validation!! please help!!!
Microsoft will give you a valid key if you report where you got this version. Tell them the store, date, etc. and you'll get a valid key.
1helpful
Windows did not pass genuine validation, you can run another validation check after you get genuine windows, m computer runs windows XP home edition version 2002 service pack 3
Hi
Thank you for your query
This message is telling you that your copy of windows may not be genuine, and you will need to purchase another license
If you believe that your copy is genuine and you have reciept etc to prove then you call microsoft to clear the issue up and they shoud provide you with another Windows key
I hope this has been helpful
My computer destop has the word This copy of window did not pass genuine windows validation??who noe dissolve this prob can tell me?????please tell me the prob how to dissolve?
Seems that you have an invalid copy of windows.... :( only way round it is to but a copy from Microsoft or somewhere else (but microsoft usually cheaper)
Or can switch to a different operating system......
There are cases of valid Windows failing validation so if you are 100% that yours is good, contact Microsoft to sort it for you
2helpful
2answers
This copy of Windows did not pass genuine validation. The product
Hello there
It can easily be done by editing a few registration keys
here is how
  1. Bypass windows Validation - The Ethical Hacking Defeating WGA (Windows Genuine Advantage) Validation Disclaimer : This article is for educational Purpose only Microsoft WGA validation check can be defeated...rahulhackingarticles.wetpaint.com/page/... - Cached
  2. Eric-Taylor.com " How To: Bypass Windows Genuine Validation ... ... "How To: Bypass Windows Genuine Validation (UPDATED)" Cruise says: ... Can bypass Windows Defender Beta 2 validation via downloadable ... Bypass windows ...eric-taylor.com/2006/04/27/how-to-bypass-windows-genuine-validation... - 59k - Cached
  3. Eric-Taylor.com " How To: Bypass Windows Genuine Validation Once you see the steps of bypassing this you will believe me when I say that "MICROSUCKS SUCKS! ... Bypass windows genuine validation! ...eric-taylor.com/2005/10/12/how-to-bypass-microsoft%E2%80%99s-windows... - Cached
  4. Bypass all Windows Genuine Advantage validation - Windows ... Haklabs has posted an 8-step solution you can use to bypass the annoying Windows Genuine Advantage (WGA) validation process for any Microsoft product installation ...lifehacker.com/software/microsoft/bypass-all-windows-genuine-advantage-validation... - 63k
When I try to validate my Windows version I get an ActiveX error
turn pop up for cookies on, certain activex controls would popup in the seperate windows for that popup should turn on...
2answers
My desktop says that my computer did not pass genuine windows val
For Windows XP Home
Restart your computer and before the appearance of the boot screen hit F8 to get the booting option list. From the list select Safe Mode in order to start your computer in Safe Mode.
Once the computer has booted in Safe Mode go to Start > Run and type c:Documents and SettingsAll UsersApplication DataWindows Genuine Advantage (where C: is usually the system drive).
Right click the DATA folder and choose Properties. Now go to the security tab and in the Group or user names section click on Users. In the permission for user section make sure you check all the check boxes under the Allow column: Read & Execute, List Folder Contents and Read. Click OK and then restart the computer. Now you should be able to validate your Windows copy.
For Windows XP Professional
In Windows XP professional there is no need to boot in safe mode. Just go to Start > Run and type c:Documents and SettingsAll UsersApplication DataWindows Genuine Advantage. There you will find the Data folder. Right click on it and follow this path: Properties > Security tab > Users > Permission for users section and verify the Allow column for all the check boxes to be selected. If not selected, do it yourself.
Now restart the validation process.
for more help go here:
http://www.mydigitallife.info/2006/03/07/bypass-and-disable-genuine-windows-validation-check/
Validation of windows
If your windows is genuine, then you should not have any problem with validation...then if it says it failed o validate, then you probably have a pirated version of windows...are you using Windows XP or Vista?
2answers
Genuine validation
you need a valid COA(certificate of authenticity). means you need a valid product key for your operating system. Once you have it, it will solve your problem.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
