Question about Black & Decker Drills
Can't tighten bit into drill-just spins- won't tighten
5 Suggested Answers
danny_murray
  • 55 Answers
SOURCE: keyless chuck will not tighten down enough to hold bit
What size bit are you using if it is real small it may be below the min sixe require for that chuck .If it is say 1/8 or larger it may be time for a new chuck .They are easy to replace open the chuck as far as you can there is a screw inside them most of them are left hand threads just back it out and tap the chuck loose with a hammer .Make sure you know the threads of your chuck when you buy the new one most are 1/2-20 but some can be 3/8-24 tpi
Posted on Dec 05, 2008
  • 142 Answers
SOURCE: locked drill chuck
i have the same tool and have had the same problem
i use 2 large prs of channel locks(water pump pliers) to break the bond
Posted on Jul 06, 2009
rowdy45176
  • 2176 Answers
SOURCE: Black and Decker corded drill won't tighten around a bit.
the chuck sounds like it is bad or maybe stuck from rust, what you can try and do is spray some WD-40 on the jaws and then try and holding the collar with a glove and run the drill SLOWLY in forward/reverse and see if it loosens up if not you will need a new one.
Posted on Jan 23, 2010
  • 90 Answers
SOURCE: how to tighten drill bit on makita 6343d
your must have a keyless chuck. hold the black center part of the chuck and run the drill forward or backward to open or close the chuck.
Posted on Aug 30, 2010
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
How to change bits
The drill uses a cordless chuck (part bits go into) you will need to hold the outside ring of the chuck and spin it to loosen the jaws on the bit. Then spin the chuck the opposite way to tighten
Sep 26, 2012 | Makita BDF452HW Factory Reconditioned 18V...
Jaws won't tighten or loosen to hold a bit
Hmmm some times the counterclockwise screw that attaches the chuck to the drill come forward and that is how then it stucks the 3 parts that fix a drill to a chuck. Check if this screw come forward. If yes then destroy it and replace it... We destroy it by using a drill smaller than it (usually it is 5mm so we use 4mm bit and of course a CARBIDE one because even cobalt ones can not drill a hardened bolt)
Mar 26, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
I have the drill, I have the bits...there is something missing to connect both. What does it look like?
Although you posted your question under Chainsaws instead of another tool forum, look at the end of the drill. Is there a hole surrounded by a cone shaped metal end? This is the chock, if you spin/turn it counterclockwise, the opening should widen to accommodate the drill bits, then spin/turn it clockwise to tighten/clamp down on the drill bit. Some drills accomplish this with an l-shaped key that has a small cone-shaped gear on the end that fits into holes on the chock. Some drills have a chockless drill, and you simply hold the end of the drill and squeeze the trigger to use power to tighten/loosen the bit.
Aug 31, 2011 | Garden
How do I take a bit out?
It is a keyless chuck. Put the drill in reverse (chuck should spin to the left when viewed from the back) and hold the main body area of the chuck with your hand while slowly running the drill. The chuck will open (unless it is broke) and release the bit. You do the opposite (slowing running the drill in forward) for tightening a bit in the chuck.
Jul 16, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How do I attach the drill bit?
You have a keyless chuck that holds the bits, just hang on to it with one hand and spin the motor with the switch, let it tighten up on the bit and hang on tight, it should grab it. To get it off, just reverse the drill motor and hang on to the chuck again, and it will come out. Check it out.
Nov 15, 2010 | Dewalt 18 Volt Compact Drill Kit
I have a craftsman electric drill model no. 315.10419, i would like to know how to loosen/tighten the chuck for the bits. it is not the regular notched tightener but has a pull down shaft similar to an...
I have the same drill and love it !! This series of Craftsman Drills are the first of the keyless chuck. To tighten or loosen the bit, simply pull back on the black ring tightly and hold it and simultaneously pull trigger to run drill foreward (to tighten bit). Reverse (to loosen bit). The chuck will make a loud clicking sound!! This is normal !
Jun 23, 2010 | Craftsman Drills
Was using with a spsde bi and hit a nail. Now
You may have inadvertently hit the hammer/drill switch and it is floating the middle between functions. This selector switch has a symbol showing a drill bit on one side and a symbol of the hammer on the other. Engage the switch bacK into the drill position
Jun 08, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Jan 14, 2010 | Black & Decker Drills
Having problems securing masonary Bit on 3/8 Black&Decker Drill 7
If it's an inexpensive bit, odds are it's spinning in the chuck. If the chuck key can't tighten the jaws well enough, you'll need to borrow or buy a different drill (or you could replace the chuck).
If you bought an SDS bit (one with slots milled in the shank), you're best off buying a bit made for a standard drill. It's not impossible to get a SDS bit to chuck into a standard drill, but it's difficult and they often slip loose during drilling, messing up the hole.
Take care!
May 24, 2009 | Black & Decker Drills
Drills Logo
77 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
