Question about Canon PowerShot SD870 IS Digital Camera
Black Screen; Change Battery Message
When I turn on my PowerShot A300 I get a black screen and a "change battery pack" message even with brand new batteries. Shortly thereafter, the camera shuts off. Any ideas are appreciated. P.S. This camera has never been dropped or abused in any way. Same issue, but i just remove the battery pack and shove it back in =). Seems to work for a few days until the message returns which i rinse and repeat.
I called Canon ( 1 800 828 4040 ) and they claim that it MIGHT be the battery's fault then gave me the option in sending it into the nearest service center so they can take a look at it with a copy of the receipt.
  • mushfadi Feb 19, 2009
    I bought a brand new IXUS 870 IS 2 days ago and i am having the replace battery pack issue ...very disappointing, what make things worse is that i lost my receipt :-(
My proposed solution is valid for a Canon PowerShot A300 (digital)
Hi there! I had the same problem with my camera and called Canon as well. They gave me the option to have the unit diagnosed (free) and serviced (base fee $80) or the option to trade it in on a newer model (my unit + up to $110 for refurbished unit).
After talking with the representative for about 15 minutes I advised him that I was going to look at the pros and cons of the units available and call them back after I had made my decision. However, right before I hung up the phone he advised me that sometimes this trick works:
Take a pencil eraser and clean the battery connections well on the outside (the little black flip up piece) and down inside. Just make sure that you clean it out well and don't leave any foreign objects in there (i.e. eraser flakes). I learned in cleaning mine that it's best to do it in a well lit area and the battery connections inside the camera push down a bit so make sure that you're gentle but you should clean the entire area in there.
As soon as I finished cleaning the connections and put my rechargeable batteries (which have been lying around for a few days without being recharged) back in the camera powered on and I have taken about 40 pictures since.
I hope this works for you as well.
Posted on Sep 23, 2008
CAMERA WON'T LET US TAKE A PICTURE
Make sure you are using either NiMH rechargabeles or quality name brand alkalines to get rid of the change battery message. As for the balck screen, it is likely that the shutter is jammed closed and the camera needs to be cleaned / serviced.
Jun 09, 2010 | Canon PowerShot S3 IS Digital Camera
CAMERA MESSAGE SD790 IS
Well, I haven't used a Canon PowerShot SD790 IS Digital Camera before, but I want to suggest this: before you start thinking of putting your camera apart, try to clean the battery terminals and the battery contacts of the camera with clean white paper, then reinsert the pack. Please be very careful when doing this so that you do not break or bend the contacts or terminals; they are usually delicate material.
Apr 18, 2010 | Canon PowerShot SD790 IS Digital Camera
The LCD monitor setting was lost after changed battery pack
Take a picture with the new battery pack. Is the picture also blank? Are the menu selections still visible in the LCD? Have you tried pressing the DISP button on the back, but the screen still remains blank?
If the answer is yes to these three questions, this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 19, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
I have a Canon PowerShot S2IS that gives me a black screen and a "change batteries" message even with new batteries. Is there a way to re-set or re-boot the camera?
Try cleaning the battery compartment contacts with a cotton swab "dampened" in rubbing alcohol. Also clean the battery contacts and the charging station the same way. Thanks, Dana
Nov 22, 2009 | Canon PowerShot S2 IS Digital Camera
Canon a300
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
May 01, 2009 | Canon PowerShot A300 Digital Camera
Black screen, put in new battery no change!???
For both of your cameras, this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
I highly recommend that you follow up on this, especially for the SD110. I think you'll be very satisfied with Canon's excellent customer service!
Apr 26, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
simple! with my Canon S90 had the same problem until I changed the SD card from LEXAR for a TOSHIBA SD card and the message " Change the Battery Pack"disappeared.
Jun 27, 2008 | Cameras
Canon Powershot A540 - Change Batteries when Batteries Fully Charged
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
May 27, 2008 | Canon PowerShot A540 Digital Camera
Stuck on Black screen
Hey buddy.....Know this first.....
Canon needs higher power batteries. You cant use Nippon of any other battereis that you use for clocks & other stuffs like torch..Buy a higher power battery....
TIP : Buy high power RECHARGEABLE BATTERIES. It cost you 200. Its must to buy a Battery charger. This combination will give you life long Battery.
No Hassles of Changing battery for every photograph...
May 05, 2008 | Canon PowerShot A450 Digital Camera
This sounds like it might be a defective CCD imager. Take a picture and see if it is also black. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
The little 3 volt button battery is the clock battery for the camera. It keeps track of date and time.
Feb 04, 2008 | Canon PowerShot A300 Digital Camera
Canon PowerShot SD870 IS Digital Camera Logo
428 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
