Question about Aspire Acer AS5315-2856 Laptop
My webcam is creating problems its showing me two differnet images
Web came show but black screen no image showing on screen
Please adjust the zoom by installing webcam application.
Check any dust is present on the webcam.
Try this also
Please download the file amcap920.zip from http://www.download25.com/install/amcap.html and install the setup.exe. It will create "amcap" in programs. click the amcap. you can see the video from cam. '
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 10, 2011 | Computers & Internet
I bought the Frontech Diamond webcam and installed the CD and the message shows its successfully installed, as its requested i restarted my system. After i open my cam,, the light will ON but in the CAM...
check if your USB cable is properly plugged.
Also try connecting your webcam directly to your PC instead of through a USB hub
if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
Feb 13, 2011 | Cameras
Troubleshooting
Instructional steps to follow
  1. Verify that the Logitech webcam is connected to your computer if your computer doesn't register its existence, if the webcam's power light isn't glowing or if no image shows on your webcam software. The webcam's USB cord should be firmly inserted into an open USB slot. For the best results, use a USB port on your computer instead of a port on a peripheral device like a USB hub or a keyboard.
  2. Adjust your room's lighting if the Logitech webcam image is excessively dark. Logitech's cameras have no built-in light. For the best viewing image, your light source should come from behind the Logitech webcam instead of shining into the webcam's lens.
  3. Quit any open programs other than the software that's using the Logitech webcam if you get errors regarding more than one program trying to use the camera (e.g., a chat software and a voice-over-IP program both trying to use it at once). This can create data problems and software conflicts.
  4. Check for updates to your Logitech drivers from Logitech's support site. The company regularly releases software updates and patches that resolve commonly encountered glitches and problems. Download the patch and double-click it to initiate an automated installation process. Your computer typically needs to be restarted before you can resume use of the Logitech device.
  5. Contact Logitech's webcam support line at 646-454-3209 if you still cannot get your webcam to work correctly. Support technicians are available weekdays from 6 a.m. to 6 p.m. PST and on Saturdays and Sundays from 7 a.m. to 5 p.m. PST. Have your model and 10-digit part number ready. Such numbers are usually located on the bottom of the webcam or on its packaging.
Oct 31, 2010 | Logitech Webcam
DISC DRIVER BROKEN ,NEED TO PROGRAM WEBCAM TO PC
I was trying to help getting the drivers online but for that camera it seems to be tricky.
I would suggest the following:
in another computer attempt to create an image file of your driver cd as you mentioned you still have it (I strongly suggest you don't lose it), then with a usb thumb drive move that image into the vista computer (the one that does not have the disc tray working). now for you to create a image iso file on the other computer (virtual image of your cd) you need nero or magiciso or another program to create iso files from a cd, now to read that image on your cd-trayless computer you can use a program called magic disc.
there are other programs you can use to make iso image files that are free
free alternatives to nero
magic disc
- this is free and it will create a virtual cd drive on your computer without cd tray, you just need to mount the iso file you created with the other programs and it will work like a cd drive so you can installation cd without ever inserting the actual cd.
good luck!
Dec 26, 2009 | Computers & Internet
Error message that does not allow me to show image on webcam
o que devo fazer quando eu abro a web aparece a seguinte mensagemCANNOT CREATE AUDIO CAPTURE FILTER;. POR FAVOR ME AJUDE.
Dec 14, 2009 | MSI Starcam 370i Webcam
Web cam showing error 8007045a cannot create video capture filter
Problem for Logitech QuickCam Sphere Webcam Web cam showing error 8007045a cannot create video capture filter
Jun 22, 2009 | Logitech QuickCam Sphere Webcam
My web cam is not show video when i start it shows only blank
Use Your Webcam in Yahoo Messenger Step1Head to the Yahoo home page, turn on Yahoo Messenger using the 'Messenger' link and log in using your account name and password. You'll need to create an account if you haven't done so already (see Resources below). Step2Click the 'Messenger' followed by the 'Start My Webcam' option. This will load your webcam, and is among the ways you can get your webcam to begin broadcasting. Step3Click on the camera icon that appears in a chat window while you are talking to a friend. Step4Click on a contact from your Contact List, then click 'Invite to View My Webcam.' This opens a new IM window with your webcam active. Step5Click the 'View Webcam' link while talking to others in IM. This will allow you to see their webcams. Step6Use the 'Super Webcam' mode when you want to send and receive high-quality images and feeds. Broadband makes it possible to see one another in very high resolution, although even with high-end broadband your computer may slow down a bit because of the amount of memory and processing power this requires. Step7Click 'Webcam' followed by the 'Who's Watching Me' button to see which of your friends is receiving your webcam's feed.
Mar 16, 2009 | Computers & Internet
Can't see me image when I use Yahoo Im webcam
This may be a problem with the webcam, but you can also go to Yahoo Messenger, and there is a wizard to set it up!
Aug 06, 2008 | Radio Shack VGA PC Camera Webcam
Quick cam shows my tv tuner channel and not my image
hello igloo,i am nichu
ya this problem is common, although it is not a problem.what's hapenning is that your webcam's source or the channel is changed ,thats why whenever you switch on your webcam you see the tv in your webcam window .
hence to avoid this change the source of your webcam ,chose option other than the tv tuner i.e., the webcam one,which is in your webcam window it is there in your options tab,,,,,,,,,,,,,,,,,,,,,,,,,,,,,problem solved.
take care
bye and have a good day
Nov 02, 2007 | Logitech QuickCam Messenger Web Camera
Aspire Acer AS5315-2856 Laptop Logo
Top Aspire Computers & Internet Experts
pankaj rautela
pankaj rautela
Jax Planet
Jax Planet
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
