Question about Bosch MUZ6MM3 Food Processor
Just got the MUZ6MM3 processor by Bosch. Can't get the base to snap on. It looks like there is a plastic protective guard that needs to be removed, but no tool or instructions were included.
Can I change the plastic motor spindle on a magimix 5100?
Yes you can, you can "cut" it off with a soldering iron by melting a slot down one side. When banging a new one on you need to remove the base and suppert the bottom of the shaft with something solid underneath it. The whole motor assembly will be sitting on this as you bang the new sleeve on with a soft mallet. If you don't there is a danger you will wreck the motor and you cannot afford to replace that bit.
Aug 29, 2014 | Magimix 5100 Cuisine Systeme Food...
Need to remove the proprietary screws from a Braun CombiMax 700
These are called Torx security bolts. You should be able to find the right size at your hardware store.
Jan 08, 2014 | Braun K 750 CombiMax Food Processor
Base gear for the top of the base
Carefully take it apart and clean it thoroughly. If you see any burnt wires, trying replacing those if you know how to replace one. As for the plastic gear on the power base, it can be easily replaced with any ordinary similar coupler of the same size, for example like the one KitchenAid supplies (Blending coupler 9704230). The only catch here is that you need to replace the coupler on the base of your choppers as well. This would be a better idea considering getting rid of the cheap plastic used in these blenders and the need for long-term use.
Jun 01, 2012 | As Seen On TV Magic Bullet Food Processor
How to tighten the nut on one of motor screws of a 7 cup kitchenaid kfp720 food processor
A gouge in the edge of a plastic button is not the end of the world, it has to come out to effect a repair. I use a sharp knife down the side, you can always blend any little damages to the plastic with the round shaft of a screwdriver.
Apr 28, 2012 | KitchenAid KFP720 7 Cups Food Processor
I got a new bosch mixer, food processor for christmas. The food processor will not go down on the main body of the mixer, because of a white piece of plastic inside the bottom of the processor. I thought...
Not too many people offer to pay for advice, but that's no problem. This is a vollenteer site.
The issue with your food processor is because the cutting chamber and lid need to be correctly assembled so that the tabs on the pot and lid line up andslip into a slot in the handle. This will move the plastic peice out of the way.
A safety device to prevent putting fingers into the pot while in operation..
Watch this video and it will explain it.. about 2 mins in..
http://www.youtube.com/watch?v=EB8fEgTzuXk
Dec 27, 2010 | Bosch Universal Plus Kitchen Machine Food...
Our new food processor doesn't fit our old Bosch
There is a separate discussion on this on fixya. The plastic piece should automatically "retract" back into the handle when you attach the processor. Some have removed teh plastic piece and reports it works then, but you should not need to do that.
Jul 13, 2010 | Bosch MUZ4MM3 Food Processor
Looking for a manual for a bosch mcm5100uc food processor/blender
thats a easy one. go to thermador.com give the model # and they will order it for you 2-7 days you will get it. let me know how you made out.
Nov 21, 2009 | Bosch MCM5100 Food Processor
DLC-7 missing a piece?
The workbowl has a spring-loaded assembly inside. You can see it through the plastic. When the workbowl cover is in place and locked, it depresses the button on the base. If this is not happening, then you need to determine whether the workbowl or the cover is at fault. Once you figure that out, you need to replace the faulty one. I usually get my replacement parts at GourmetDepot.com.
Dec 20, 2008 | Cuisinart DLC-5 Food Processor
Food processor attachment won't fit the machine
I actually got tired of trying to figure it out and just unscrewed the bottom and removed the plastic part. It works fine now!
I had a screwdriver to use with a mobile phone, I think its called t9 or something.
Jan 10, 2008 | Bosch MUZ4MM3 Food Processor
Bosch MUZ6MM3 Food Processor Logo
53 people viewed this question
Top Bosch Food Processors Experts
Ross Keen
Are you a Bosch Food Processor Expert? Answer questions, earn points and help others
