Question about Keurig B60 Coffee Maker
When my coffee starts to brew, the coffee (water) does not come down in a nice single stream. It is all spread out (kind of like water rolling off an umbrella) and some of it misses the cup. Also, alot of the coffee includes the coffee grinds. I tried it with just water (without the coffee cup) and the water stream behaves in the same way. Any suggestions? Thanks, Andy
  • 1,772 Answers
Sorry to read about your issue.
in addition to below take a pin and clean the little tube
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Jan 01, 2011
Why am i getting an error when I try to brew on the single serve side of my Hamilton Beach flexbrew?
Check your water level if there is to much water you will get an error message. Try removing some water and try single serve again.
May 02, 2015 | Hamilton Beach Coffee Makers & Espresso...
Why does my machine brew coffee very slowly almost dripping instead of brewing at regular cycle?
it might need cleaning solution to use is vinegar pour vinegar in it and turn it on let it fill the pot up hope this works good luck
Feb 26, 2015 | Cuisinart SS-700 - Single Serve Brewing...
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
Coffee brewing comes out in a fast steady stream when brewing, coffee doesn't brew properly and comes out weak. taste like unbrewed.
If it comes out in a steady "stream" it sounds like the sprayhead is missing. The sprayhead disperses the water out and evenly over the grounds.
If the sprayhead IS in place then it could be a temperature problem. If the temperature is not hot enough the coffee will not brew correctly.
Sep 06, 2010 | Bunn Coffee Makers & Espresso Machines
My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
May 31, 2010 | Breville BKC600XL Coffee Maker
Steam works great. Problem is, very little water comes thru the machine into where the coffee grinds are. I have primed. Nothing. I have cleaned the screen. Nothing.
Remove the screen and screw in the head and make sure screen is clean, press brew button with screen off, if you get a nice stream then problem is solved, if you get no stream, then you will have to remove the 2 allen wrench screws and check spring and plastic valve, male sure they are not blocked.
Feb 10, 2010 | Gaggia 16002 Espresso Machine
Keurig B60 Coffee Maker Logo
156 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
