Question about KitchenAid Architect II KUDS40FVSS Builtin Dishwasher
Clean light blinks 7 times in a row in a pattern
  • 4,323 Answers
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Posted on Jan 01, 2011
4 Suggested Answers
  • 949 Answers
SOURCE: Blinking Green Light
This indicates that the water did not heat properly. Follow the link below for instructions on what causes this and how to reset the control so you can use the dishwasher.
Blinking Clean Light
Posted on May 31, 2010
Daniel S
  • 4323 Answers
SOURCE: The clean light blinks in
Hi
Posted on Feb 17, 2011
KevinWhite
  • 1902 Answers
SOURCE: The clean light is blinking
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Posted on Apr 26, 2011
Clean light blinks
clean light blinks is a form of error codes. The most common is a heater circuit error, 7 times then a pause is the heater. to clear the code press the heated dry then normal in a key dance 4 times. this starts a diagnostic cycle, takes several min to complete. let it run. it will work until it sees the fault again. this code is caused when the main control does not read a water temp increase 3 times in a row. If this continues call for service.
Jan 08, 2012 | Maytag Dishwashers
Normal light flashes, unable to operate
Hello.
The reason the ligh keeps blinking is because it is displaying a error code. How many times in a row does the light flash before it pauses and blinks again?? the number of times it blinks in a row is the number of the error code its displaying...example if it blinks 7 times in a row before a brief pause its is displaying the E7 code and so on.
This tip i wrote will tell ya how to reset the control board but be sure to reply with the amount of times it blinks and i will let ya know whats its telling ya.
Here is that tip to reset it http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Sep 24, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The dishwasher will not come on and the clean light is flashing.. We have hit the cancel button but the light is still blinking. We have also un plugged the dishwasher to try to reset it and the light is...
I have wrote a tip about resetting the control which i have posted below. My question though is how many times in a row does the light flash,depending on the consective times it flashes before pausing them flashes the same number of times indicates what error code it is...example if it flashes 7 times in a row that is error code 7 if it flashes 4 times that is error code 4 and so on
here is that tip of what ya need to do to reset the control board
http://www.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
please reply with how many times it flashes then pauses then flashes again and i will determine what error code is being displayed
GENE
Sep 17, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The clean light is blinking 7 times in a row then there is a small pause and it starts again. None of the settings work.
Kevin
Apr 26, 2011 | Dishwashers
May 31, 2010 | Whirlpool 24 in. Built-In Dishwasher w/...
HP Pavilion dv4 not booting up, has blinking caps and scroll lock
Compaq and Hp are having issues with several models, My wife just got hers repaired free out of warranty. Go to copaqs website, look up your model and see if it is one they are offering free one time repairs on. Wife's computer was doing same thing, they replaced the motherboard. Took about 2 weeks round trip . Good luck
Feb 02, 2009 | HP Pavilion dv4000 Notebook
The light blinks 12 times, and nothing will print
suggest you need a new set of printer drivers
remove old version first
go here for new ones
re install
Mar 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
KitchenAid Architect II KUDS40FVSS Builtin Dishwasher Logo
111 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
