Question about Apple iPod nano 3rd Generation
Why does my ipod play music with my headphones in it.
    Scholar:
  • 104 Answers
Dear joycemdais2,
- Check if the volume is open: scroll with the click wheel to check if the volume is open - See if volume limit is disabled in Settings
Kind regards
Posted on Jan 01, 2011
Wont play music
sounds like you have removed them by pulling on the wires, not by the earbuds or plug. not a recommeded practice when unplugging anything as it usually ends in broken wires internally along with tears. You may be able the get somebody to do some faultfinding/repairs if they are of the super expensive variety otherwise replacement may be the only solution. Most in-ear headphones have super delicate wiring and are as such a real pig to resolder
Dec 08, 2012 | Kicker Flow EB72B Personal In Ear Noise...
I transferred music to my mp4, however I cannot hear it when it plays. I know it was transferred correctly, but the music bar moves/plays but no sound is heard. My headphones are new.
Try a different set of headphones, if there is still no sound, check the volume limit on the iPod: http://support.apple.com/kb/TA38403?viewlocale=en_US
if that still does not help try resetting it by pressing the MENU and PLAY buttons simultaneously for a couple of seconds, I hope that did work. But, if it didn't, try doing the diagnostic in it to find out if it is a faulty jack: http://www.wikihow.com/Hack-an-iPod-Nano-3G Hope it is just headphones!
Jan 19, 2011 | Apple iPod nano
My apple iPod nano 5th gen wont play music through the headphones right. It only plays through the internal speaker even with the headphones in. I can hear it through the headphones a little but it is...
take the headphones out play the music full volume then put the headphones in and lower the music all the way down then your volume will be normal and it will only play in through the head phones unless you take headphones out then it will play through speakers
Aug 30, 2010 | Apple Logitech Inc MM50 Portable Speakers...
Right headphone will not play music
sounds like a broken wire. have them exchanged.
Mar 22, 2010 | Bose in-ear headphones - Black with...
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Hello I have my problem is that my jailbroken ipodtouch(2nd genertation) will not play music.It wont play sound the songs play but the sound you cant hear.Can any one help me?
Did the songs you're trying to play work previously/is it all music on the ipod? I believe if you plug the ipod into your computer and hit the restore button in iTunes it wipes everything and resets the factory settings. Seeing as jailbreaking it technically voids the warranty, there's no "official" way of fixing it - but this has worked for me in the past. It could also be a problem with your headphones or the headphone jack. Before wiping it, I'd test it with some different headphones to see if that solves your problem. You can also try a reset on the iPod itself by pressing the sleep and home buttons at the same time for about 10 seconds. This doesn't erase anything, but it does reset the device. Since there are so many things it could be, you may want to try the less severe ones first, then back up your music and the like before doing the iTunes factory reset - then bring it in to Apple to let them know that you can't play music.
Jun 10, 2009 | Apple iPod touch
Left ear no music
Before you worry about repair, verify that the balance control in the iPod isn't causing the problem. The easy way to do this is to try some other audio device (home stereo, etc).
Mar 19, 2009 | Coby CV-190 Consumer Headphones
Music outside the iPod
You can't because you can't. It is not a speaker that is meant for music, last time i checked it was pseudo something but forgot the exact name, its not able to make audio, just ticking sounds. Its sort of like the 'beep' that happens when your computer starts, you can't make that speaker play music it just beeps..
Mar 08, 2009 | Apple iPod nano MP3 Player
IPod Not Working
Does your iPod come on? If not, your battery could be bad.
If you can see the music playing, but cannot hear anything, you could have a bad earphone jack or a bad circuit board.
You can tell if it is the battery the iPod will not come on at all unless it is attached to the computer or to a power outlet.
If you can move the earphone jack around while playing music and hear something, then it is the headphone jack. If you move the jack around and hear nothing, then I would suspect the circuit board.
If you have a device that can play your music out of the USB port on the iPod, you can make sure that it is the circuit board that way. When the circuit board is bad, music will not play out of the headphone jack or the USB port.
Hope that helps.
Dec 09, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano 3rd Generation Logo
27 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
