Question about Kenmore HE3T Washer
My HE3 washer is displaying F35 error - Kenmore HE3T Washer
  • 457 Answers
F35 indicates a failure of the water level pressure analog sensor, it has a maroon coloured plastic case size of a match box and is located in a corner directly under the top panel cover.
  • Disconnect power before opening the panel. Do it.
  • Check if any cable went loose to this device and fasten.
  • Close the panel, reconnect the washer to power and check if the error went away.
  • If no, you can order a replacement sensor HERE
Posted on Jan 01, 2011
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
The F35 failure is displayed if the analog pressure switch has a calibration error.
There are two things you can check for this problem if you're comfortable with do-it-yourself.
Remove the washer top to access the pressure switch on the right hand side of the cabinet near the top. See the image below. You'll want to check if the pressure hose is fixed correctly and not loose. Check if the Air trap is not blocked. You can do this by removing the hose and blowing in it towards the tub. It should blow freely and you might even hear bubles. If you can't blow or it's hard to blow then most likely the hose is kinked or blocked.
If the hose is not blocked or kinked then the pressure switch W10156252 is most likely the problem and will need to be replaced.
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Keeps Stopping and saying UE
    uE error code 79631512210 Kenmore Elite Washer - Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
    UE Error code on my front loading Kenmore washing machine
    www.shopyourway.com > Manage My Life > Questions
    Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
    Jan 21, 2016 | Kenmore Washing Machines
    Kenmore elite front load washer model 46752701 after replacing pressure control switch i still get f35 code
    Most common cause for the F35 error code: Using non-HE detergent. Detergent slime builds up in the hose, eventually getting into the analog pressure switch and killing it. Make sure you flush out as much soap as possible and make sure to use HE soap or it can keep occurring, also some vinger can calm down the suds
    Oct 26, 2013 | Kenmore Elite HE3 Steam 8674 Dryer
    My HE3 washer is displayer an F35 error
    Sorry to read about your problem, I hope this helps you out.
    Remove the washer top to access the pressure switch on the right hand side of the cabinet near the top. You'll want to check if the pressure hose is fixed correctly and not loose. Check if the Air trap is not blocked. You can do this by removing the hose and blowing in it towards the tub. It should blow freely and you might even hear bubbles. If you can't blow or it's hard to blow then most likely the hose is kinked or blocked.
    If the hose is not blocked or kinked then the pressure switch is most likely the problem and will need to be replaced.
    I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
    4 Thumbs - Very Helpful
    3 Thumbs - Helpful
    Jan 01, 2011 | Washing Machines
    Washer displaying F35 error message??
    F35 Error
    ANALOG PRESSURE SENSOR FAILURE
    If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
    1. Check if pressure hose is fi xed correctly.
    2. Check if the airtrap is not blocked.
    3. Check if the hose is not blocked.
    Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    What is the F35 error code on kenmore elite he3 washer and how can i fix it
    F35 is a water level error.
    The water level switch (pressure switch) has malfunctioned.
    If you remove the top panel, three screws in the back, you will have access to the pressure switch.
    With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
    If the fault codes return after doing this, you will likely need to replace the pressure switch.
    Also - please be sure to use He soap.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Sep 08, 2010 | Washing Machines
    F35 code
    The following list of codes indicates an electronics communication problem with the washer:
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
    To remove the error display, press Pause/Cancel twice.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    Take care
    Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet -Sud displays and washer stops
    I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
    http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
    I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
    Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore elite he3 front load
    I had the same issue with a brand new wash. The issue I found was the installers installed the drain line too low. The drain line needs to be a minimum of 39" above the floor. Hope this helps -- Kent
    Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
    Sears Kenmore HE3 Error Code F35
    Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore HE3T Washer Logo
    114 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
