Question about Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher
How to run diagnostics on bosch shx46a06 - Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher
Cycle does not finish leaving dirty water bottom of tub without draining out
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 12, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Both upper and lower water dispensing devices are not spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 01, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
OUR BOSH 24 IN SHX46A02 BUILT IN DISHWASHER WON'T DAIN
consult handbook for checking for blockages this is a user serviceable component and can be serviced easily.
May 27, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Dishes Don't clean
If the machine motor runs and the cycles all seem to be working.Check if the rotating arms are spinning when the machine is turned on.
If it isn't then the water pressure is too low and not spining the arms. You have a pump problem, likely the impeller is broken. I had the same issue with mine
Apr 26, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher Logo
450 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
