Question about Garden
I have to pull on the starter cord 12 to 18 times before it will start. it will start every time but too many pulls. i use high noctane gas. i prime it at least 7 times as per the instructions
  • 91 Answers
I ve had the same problem all i did was take the filter off and open the chock to give it air and it starts everytime.
Posted on Jan 01, 2011
How do you start it/
Check:
- Gas in gas tank
- Oil level correct.
- Tiller drive in off/disengaged position.
Start procedure:
- Fuel selector - ON
- Ignition switch - On
- Choke - On
- Throttle position - Slow
- SAFETY - No children within 10 feet/
Pull Starter rope......
Repeat 3 - 5 times only.
If engine starts, release choke as required until engine runs smoothly.
If no start,
- set Choke to OFF, Throttle to FULL,
- pull starter rope 3 - 5 times only.
- if start, reduce throttle to obtain smooth idle
- if No start, start check for:
- Spark at plug
- Fuel in the jug
May 22, 2015 | Garden
How do we start new chainsaw first time?
Install wire on spark plug. Turn switch to "on".Prime the gas with a 2-3 pumps, close the choke and give cord a pull. Don't pump the primer again or you can flood it out. Open the choke and pull cord until it starts.
Mar 16, 2015 | Garden
How do I start my Mastercraft snowblower
check gas and oil
check blower housing (round part) for ice and snow ( clear if needed)
put gas and choke on full
prime 3 times pull cord or hit electric start
repeat if it doesnt start with priming 3 more times
Jan 03, 2015 | Garden
The saw has good compression! ive done everything i related to running and still cant get it to start im stumoed any suggestions?
For all small engines, check for spark (pull the plug, ground the plug's metal body to metal engine block, pull cord and look for spark in the gap). If you have spark, prime the head with about 1 teaspoon of gasoline or a squirt of starter fluid through plug hole, replace plug and try again. If it runs for a few seconds and quits after several attempts at priming, your carburetor needs cleaning. Probably gummed up with old gas (not drained)... a sticky situation. Remove, dismantle and clean with carburetor cleaner or replace. Next time, empty gas and run it dry.
Oct 28, 2013 | Husqvarna Garden
I have just purchase a Sears 22 Lawm mower, with a Briggs and Stratton 158cc engine. I prime the motor it act like it wants to start but then dies. I pull it and try to strat it several more times and it...
The procedure for starting an engine is as follows:
  • Check that you have the throttle in the start position and/or on high revs with choke on
  • Prime the engine by pushing the button about 5 times
  • Pull out the cord until you meet resistance. Then let the cord go fully back into the engine and then pull the cord out sharply. Repeat this until the engine starts but not more than a few times.
  • If the engine doesn't start, try pressing the primer button another few times then try to pull start the engine
  • If the engine doesn't start after a few pulls it may have flooded so leave it for a few minutes before pulling the starter rope
Apr 30, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Bought a Poulan Wild Thing 18" gas chainsaw (P4018WT) secondhand from someone who only bought it to cut down 3 trees. It will not start. I know that it works, as the guy started it up and showed me how...
Don't prime it 6 times.
Prime it once and try starting. Keep trying with one prime.
If that doesn't work, let it sit for a bit. And then prime it two times and try starting again.
If that doesn't work, try priming 3 times.
Then try half-choke with one pull only, and then move choke to run for the second pull.
The saw might have an on-off button
Oct 15, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
It won't start.
Prime away... on a chainsaw it does NOT squirt fuel into carb. It draws fuel from tank, through carb, and returns it to tank.
Using the choke however will flood it in a second once it has fired. with a good fuel supply, 99.5 % of chainsaw won't start problems are flooded. Lou
Nov 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
