Question about Refrigerators
Frigidare refrig. It seems like Freezer still working but not refrig. Temp is now 56 in refrig part. Refrig is not even 2 years old. Fan seemed to be working in refrig earlier but now not at all.
    President:
  • 2,468 Answers
Check the damper vent door between the two compartments to make sure its open to let the cold air in from the freezer then make sure the evaporator fan is operating to help push air thru this door,sometimes these doors freeze shut or if its a motor driven vent door the motor could be bad too
Posted on Jan 01, 2011
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Refrigerator keeps freezing. Temp stays at about 28 degrees. temp control on door (digital) and no matter how much you turn it up, temp stays below 30. Repair man came out and said seal was bad on...
Most likely one or both of the thermistors are bad. Usually pretty easy to find behind a vented cover about 2" X 1" on the side walls of the refrigerator and the top of freezer (if freezer is on the bottom of the unit)
May 31, 2011 | Refrigerators
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
KA KSRS series lost cooling in refrig only
Check for frost accumulation in freezer or no freezer fan
Jan 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Chirping noise from Freezer and Refrig
Simple fix. Unplug refrigerator, locate fan, wipe clean from collected dirt etc. and spray a little WD-40 on the shaft. Spin the fan. Plug in and voila, chirp is gone.
Permanent fix, replace motor.
Nov 21, 2008 | Refrigerators
Admiral refrig
thats the fan hitting ice. sounds like a defrost problem. does the back of the freezer panel have any frosty ice build up?
Aug 18, 2008 | Maytag MZD2766GES Side by Side...
GE refrig model PSH23SGPABS
The main board needs to be replaced.
May 05, 2008 | GE Refrigerators
Freezer is very cold and refrig is not
make sure the return air is open, that is a vent on the side wall of the refrigerator above the crispers on the center mullion. and check to see if the evaporator fan motor is running.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
