Question about Kwikset 907 907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt
I am try to unlock the door when i enter the code you can hear the lock working but the door will not open. what am i doing wrong
  • 963 Answers
Installation instructions:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
Go to page 6; you probably have the jumper in the wrong position for your application.
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Posted on Nov 05, 2011
How can I open a yescom wall safe in which the key is locked inside and no code has been programed in yet
Hi, One of my friends working in the hotel had told me about how to program Hotel Room Safes code. As you locked the key inside. Try to program the code. Press the red button on the back of the door near the hinge, release it and you will hear two beeps. After that, enter a code that you wish to use as a combination, and confirm by pressing the button.
Now try to open the safe, enter your combination code and confirm by pressing the button. You will hear a beep and the green light will light up. Within 5 seconds, open the door using the knob.
May 06, 2017 | Locks & Locksmithing
I have bought a used red head safe. It's open but I can't get it to close. Also, I don't have a combination for it and I'd like to make up my own. Can you help me?
Most likely it will not close because the lock has been activated while the door was open. Probably need to take it to a locksmith.
Jan 03, 2017 | Home Security
Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
Jun 30, 2014 | Other Sports Afield Executive Gun Safe...
How do i change my code on my safe? it is a S-25E i have keys but want 2 change the code
Try this,
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
Good luck
Thanks
Apr 29, 2011 | Office Equipment & Supplies
I have a 1997 Ford Expedition and the lock and alarm system is acting up. The driver?s door panel that will lock or unlock all the doors does not work. It will lock but not unlock the other door. The...
Check that you are enter the right code for open locks; for lock you dont need enter the personal code, just push the numbers pad. For unlock, you need the roght code, maybe you need reset and re-enter one new personal code.
Feb 11, 2010 | 1997 Ford Expedition
Keypad door lock does not work..?
it's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
Keyless Entry Keypad To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
  • Enter the permanent factory code.
  • Enter the owner's alternate code.
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment. To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s). To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) . To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.) This will turn off courtesy lamps and arm anti-theft alarm control (if equipped). To program an alternate code:
  1. Enter the five digit permanent entry code into keyless entry keypad .
  1. Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
  1. Enter any alternate five digit code within five seconds of pressing 1/2 button.
    • Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
      • 9/0 — no memory recall
      • 1/2 — memory seat position 1
      • 3/4 — memory seat position 2
      • 5/6 — memory seat position 3
    • After successful programming, the doors will signal by locking and then unlocking.
  • Keyless Entry Keypad Does Not Work Properly
  • Circuit.
  • Keyless entry keypad.
  • Electronic door lock control processor.
  • Open Fuses:
    • Town Car and Crown Victoria/Grand Marquis
    • Power Distribution Box (under hood)- K, 40A (Maxi)
    • Instrument Panel Fuse Panel - 17 (10A), 10 (20A), 8 (15A), 5 (15A) and 4 (10A)
  • Loose Connectors
  • Corroded Connectors
  • Oct 04, 2009 | 1995 Lincoln Town Car
    Door key pad, won't unlock door
    1. Enter the permanent factory remote keyless entry (RKE) keypad code.
    1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
    1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
    1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
    1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
    1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
    1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
    Jan 23, 2009 | 2005 Ford Freestyle
    Nokia 6500 slide help i need restriction code
    PLEASE READ FULL INSTRUCTIONS BEFORE DOING ANYTHING
    TRY WITH NO SIM CARD IN THE PHONE
    Doing this is at your own risk!
    Every code unlocks a certain lock. Code number 7 usually unlocks them all but some phones are 'buggy' and will not accept code 7 at first then use code 1.
    Usually you only have to use code 1 or code 7.
    #pw+xxxxxxxxxxxxxxx+1#
    1. Press ( # ) on your phone
    2. To get ( p ) press ( * ) 3 times within 1sec
    3. To get ( w ) press ( * ) 4 times within 1sec
    4. To get ( + ) press ( * ) 2 times within1sec
    5. Enter the 15 digit code
    6. To get ( + ) press ( * ) 2 times within 1sec
    7. Enter code number
    8. Press ( # ) on your phone
    Now your phone is unlocked!
    If your phone isn?t unlocked after code 1 or code 7 then you have either entered the wrong IMEI or Network. Sometimes there could also be a problem with newer software versions. Then you can try another 'Boxserial' Remember! You have only five tries to enter the right code. After that you will need a cable to unlock your phone. So please, be aware
    Phone type: DCT4
    IMEI: 352027025104628
    Model: 6500
    #pw+319926630701132+1#
    #pw+702310427045122+2#
    #pw+754840072200550+3#
    #pw+093433717136641+4#
    #pw+199064315752575+5#
    #pw+286305406405613+6#
    #pw+307016424512121+7#
    There is 4 locks on a Nokia DCT4 phone.
    Lock 1: MCC+MNC (Network och landsspecific)
    Lock 2: GID1 lås (SIM-card typ)
    Lock 3: GID2 lås (SIM-card typ)
    Lock 4: MSIN lås (SIM-card specific lock)
    The generated codes open up one or several locks.
    Code 1 open lock 1
    Code 2 open lock 2
    Code 3 open lock 3
    Code 4 open lock 4
    Code 5 open lock 1 and lock 2
    Code 6 open lock 1 lock 2 and lock 3
    Code 7 open lock 1 lock 2, lock 3 and lock 4
    Let me know if you have any problem follow these instructions and you should be ok.
    I think it needs to be done with no sim card in the phone remember you only get 5 goes after this if its still not unlocked then the only other option is with a lead and unlocking software.
    This should solve your problem let me know how you get on ok
    This is done at your own risk!
    Aug 02, 2008 | Nokia 6500 Slide Cellular Phone
    Fdl Code on whirlpool front load washer
    remove bottom panel reach up to bottom of door lock there is a small tab pull it down door will come open..if after opening you finda lot of water still in machine suspect pump plugged worse case bad control bd
    Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    I forgot my lock code i tried my old lock code but i wont open, so i turn it off. after a few minutes i opened it again i enter my lock code again but still it wont open, what do u think should i do???
    SIM pin code:
    This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
    if your sim is put into another handset. To reset it, you need the PUK code:
    Pin Unlock Code (PUK)
    If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
    "One day, I'm going to procrastinate..."
    May 04, 2008 | Nokia N70 Cellular Phone
    Kwikset 907  907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt Logo
    64 people viewed this question
    Top Kwikset Locks & Locksmithing Experts
    Jim Thurston
    Mike
    J.D. Browning
    J.D. Browning
    Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
