Question about HP Office Equipment & Supplies
How to insert cartridge hp60 tri color & blk.
  • 6 Answers
SOURCE: Problems refilling the HP60 cartridge
had the same problem with this hp60 before .. so when i bought a new cartridge i refilled it before it runs dry ... i'm now on my third refill and it works on both black and color
Posted on Jul 08, 2009
  • 3 Answers
SOURCE: put in a new color cartridge, but it still prints blk & white
Go in to the setting to see if you have enabled colour, it may be set to print in black only. check the cartridge to see if the ink is actually coming out. I once had the same problem when using a refillable cartridge and the chip on mine was faulty and had to be taken back to the shop.
Posted on Mar 12, 2010
  • 56 Answers
SOURCE: My printer is telling me
the Cyan is the blue ink. Try taking all cartridges out and power cycle. Then the unit will ask for the cartridges again so install them. This will refresh the sensors. If the error persist and if its new try to contact the reseller to get it replaced
Posted on Sep 08, 2010
  • 3278 Answers
SOURCE: just inserted new color cartridge and continues to
Hello.
Since you have removed the tape, be certain that the cartridge is inserted correctly. Check the expiration date.
If inserted correctly and the cartridge date has not expired, your cartridge is probably faulty. Return it for a replacement.
Hope this helps.
Posted on Oct 05, 2010
SOURCE: my printer hp deskjet f2410
Unplug the power cord from the back of the printer while its ON
now Press and Hold
Ok and Cancel button at the same time
While holding them plug in the power cord
Once the printer turns on release the buttons
You will see the Reset message on screen of your printer and in the process it will align the cartridges
Posted on Apr 07, 2011
I bought an hp60 ink cartridge set and when I installed them the printer said there is a problem with one of the cartridges. I determined it was the tri color one. I tried numerous times but no luck.
Maybe you have the cartridges switched. Be sure you don't have the color cartridge in the black position. How did you determine the tri-color was the problem?
Oct 06, 2017 | The Office Equipment & Supplies
Cannot make the printer work after I changed the ink cartridges?
You can validate the HP60 ink cartridge's electrical health by running the 'Tap 41' diagnostics test (this procedure is specific to the F2480 model). Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=440
1. While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
2. Release the Power button.
3. The 'Tap 41' diagnostic test print should print.
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout. http://inkjet411.com/?page_id=434
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Sep 01, 2013 | HP Deskjet F2480 USB 2.0 All-in-One Color...
NOT PRINTING COLOR (INK LEVEL GOOD) PRINTS ON BLK/WHITE MODE
Your color cartridge may need some cleaning. If you're using Windows, go to Start menu > Prorgrams/All Programs > Lexmark 2600 Series > Solution Center. Go to Maintenance tab and select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If problem continues, try to insert a different known working color cartridge to determine if it's a faulty cartridge issue.
Jul 29, 2011 | Lexmark X2690 All-In-One InkJet Printer
My f2400 deskjet printer show cartridge problem in tri cartridge and it was not print the document
You must be using HP60 for your printer.
Is it brand new original cartridge you tried?
If so, you'd better get refund.
If not, did you refill your cartridge?? And how did you refill?
If you used needle & syringe method, the air gap may be made during refill.
If air is inside of cartridge, you may not get decent print..getting skipped lines.....
What you got to do is, **** out the ink and try to get rid of the air gap.
And try again.
For your reference, here is how you refill HP60 in easy way:
http://www.youtube.com/watch?v=tZlkJ-YDsZA
Wish you can get some answer here.
Jul 12, 2011 | Office Equipment & Supplies
I recently changed countries and my HP C7280 printer that used to accept 02 cartridges now refuses to accept 363 cartridges, used at this region. how can i fix this?
I have the same problem but mine is the HP F2483. Takes HP121 cartridge and says HP60 is compatable but when I cahnged cartridge to HP60 it says incompatable. How do you change the configuration to accept the compatible cartridge ???
Jan 29, 2010 | HP Office Equipment & Supplies
Feb 13, 2009 | HP DeskJet F4280 All In One Printer InkJet
20 people viewed this question
Seeker5211
Seeker5211
