Question about Kenmore Dishwashers
We purchased our home 3 yrs ago and already has a Kenmore dishwasher (model #587-16163401 Serial #TH44058725) The previous owner didnt leave the manual so we have no idea how old our dishwasher is even tho it doesnt look that old as its stainless steel. Everytime we use the dishwasher...smells comes out of the sink briefly and its really stink! IT doesnt seems to clean the dishes as good as it should be and on the bottome of the dishwasher looks like a round filter like thats removeable but it doesnt stand straight in the hole like it should...uneven.
docjohn174
  • 943 Answers
SOURCE: Standing Water in my Dishwasher
hi this is the electric pump thats in your dishwasher. its probably seized up.remove and clean it just might be dirty thanks the appliance doc,
Posted on Oct 16, 2008
  • 10865 Answers
SOURCE: Dishwasher won't clean
It sounds like you need to use a chemical cleaner to remove lime, or other sediment from your machine. If you go to the following web site you will see a product called dishwasher magic which will thoroughly clean it out. Use this product at least once a month to keep your problem from reoccurring.
http://www.appliancepartsonline.net/index.php?category_id=21&target=categories
Posted on Feb 07, 2009
SOURCE: Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Posted on Feb 20, 2009
  • 9 Answers
SOURCE: Sink
"Wink" is and excellent product and can be found at many stores. You can use it for toilets, clothes and many other items as well.
Posted on May 14, 2009
Bfsas1
  • 258 Answers
SOURCE: Siemens SE64A630 GB I got a tingle up my arm
I would say it is an earthing problem, check over your earth wires, normally black and grey is neutral, check to make sure your earth wires are connected properly, and tight, better to completely turn appliance off by disconecting power plug while doing this, take care not to play around with the wires too much to prevent a nasty electric shock
Posted on Jul 01, 2009
Puma trailer, Why is 2yr old Fridge not covered under warranty?
Contact the manufacturer of the fridge, perhaps their owner relations dept can assist you. If it's Dometic, go to : (www.dometicusa.com ) Have your model and serial number ready.
May 06, 2014 | Palomino RVs
Reset code for honeywell alarm HELP
Unfortunately there needs to be a little bit more information. If you look on the security board there should be a white sticker. I need that model number to know how to program the board.
Aug 23, 2012 | Honeywell Home Security
Want owners manual for kenmore dryerelite heavy duty king size capacity ultra quite pake
Sometimes all you need to get your major home appliance working is the use and care, owner's manual or user's guide that has long since disappeared. The resources listed here will help you to get a replacement manual with the minimum of fuss.
Some of the larger manufacturers now make owner's manuals, care and use guides and installation instructions available for download on-line in Adobe Acrobat .PDF file format. If you don't already have the Adobe Acrobat plug-in for your browser or an Adobe Acrobat file reader, you can get it for free here:Of course the exact model number off the appliance (and occasionally the serial number as well) will be required to get the proper manual for it.
If you need help in locating the model and serial number identification tag on your dishwasher, fridge, stove, clothes washer, dryer or other *major* home appliance, check the Appliance411 'Repair Parts' section's
Dec 21, 2010 | Dryers
Kenmore 665 Dishwasher with a flaky heating element...
replace the heating element for the fix , somtimes they can be replaced without reomoving the unit.
Phil
Jun 10, 2009 | Dishwashers
Kenmore Elite 17483 Dishwasher Caught Fire!
Had the exact same problem (Control panel burning up, sparking, and smoking during wash cycle) last night with our Kenmore Elite DW model 665.16293400 purchased Nov. 2004. I have reported it to the CPSC and www.kitchenaidfire.com and will be contacting Sears first thing tomorrow. It is outrageous that this problem is apparently so widespread with nothing being done about it! I have no doubt my kitchen would have been in flames if I had not been sitting right here to shut off power to the D/W.
Feb 04, 2009 | Kenmore 24 in. 17483 Built-in Dishwasher
Oct 15, 2008 | Kenmore Dishwashers
Dishwasher
Hi lilwing,
I'm Harvey the Master Plumber.
Your question is: you have a ge dishwasher you purchased two years ago. you have misplaced your owners manual. you can only tell you it is a ge quietpower 3. you don't even know the model since you've misplaced your owners manual. it started with the timer for speed cycle set itself between 50 and 60 minutes, and you knew that wasn't right. and then yesterday it did not drain all the water out. you know there is no food particles in it because you clean them before you put them in the washer and the drain line it is hooked up to is working proberly also. can i help?
First, the model and serial numbers are in the door jam. Open the door and look right and left.
The rest sounds like a bad control board, It will require a pro. If the d/w has a few years on it you may want to consider the price of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
46 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
