Question about KitchenAid Architect® II KWCU405SSS Stainless Steel Kitchen Hood
The range hood display is showing a "C". We had
Press and hold 'H' for 4 seconds - then press '+' which will reset the 'C' until the next cleaning reminder
Posted on Jan 02, 2011
  • stephenandma Mar 19, 2011
    Didn't work for us ... any other solutions?
  • brendan823 Aug 17, 2011
    I had to hold the "H" button for the 4 seconds and then while still holding the "H" button hold the "+" for another 4 seconds. Not exactly how it was described in our manual but it worked none the less.
Over the Range Lights & Fan Failed. GE Microwave Oven JVM172G
It's not a fuse issue.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
We see and repair this a lot. The problem is on the control circuit board.
You can have it repaired or replace the smart board yourself.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here's a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes. Then...
Some connectors have a lock.
Then you remove the defective board and install the new one in your frame. Be careful, since the display is made of glass.
Jan 29, 2013 | GE SpaceMaker Microwave Ovens
Car does not start on "P" mode
possible cause to your problem could be faulty transaxle range switch or fault in the TCM.
Nov 12, 2012 | 2004 Hyundai Santa Fe
Our Kitchenaid Range Hood model KWCU405SSS has a code "C" in the display. What does that mean?
I just did this and it works.
1.) Make sure to turn off both the fan and the lights. If you skip this step the next step won't work.
2.) Press and hold the + button for 4 seconds until the "C" disappears.
Repeat in another 100hrs of use.
Mar 19, 2011 | KitchenAid Architect® II KWCU405SSS...
To change the Date and Time on my Sharp EL-1801PIII Calculator your instructions refer to a faceplate, which I do not have. What keys are associated with "Time Set," "AM/PM,"...
GRAND TOTAL / RATE SETTING MODE SELECTOR:
"GT": Grand Total
"•": Neutral
"RATE SET": To set the date, time, and tax rate, set this switch at the "RATE SET" position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as "date" if the
value is within the following range; "Error" is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit "0".
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as "time" if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Dec 16, 2010 | Sharp Office Equipment & Supplies
I got hood Faber Moda Lumia 90 ,and on display writes FF.What
I did not solve the problem,but I don`t have the money for your answer.I thought it is free.
Thanks.
Sandra
Aug 24, 2009 | Faber Kitchen Ranges
Hood fan works but displays the letter "C" ?
wow! finally the solution that works! Holding the '+' sign for 4 seconds. We had our vent replaced by kitchenaid once and were about to call again and complain since our new one did just the same thing without resolution using the 'H' button as indicated in the manual! Thanks for help it's so appreciated!
Feb 22, 2009 | KitchenAid KWCU205HSS Kitchen Hood
Fan to blow heat not working 1995 range rover county lwb
check your files with a circuit tester! they may look okay with your eye but be sure get a circuit tester
Dec 22, 2008 | 1994 Land Rover Range Rover County
No door lights, vent fan or microwave
That's what I thought.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 14, 2008 | Whirlpool GH4155XP Microwave Oven
Display show "file"
The range is telling you to clean the filters. To clear the display, Press and hold the "-" and "+" buttons for 5 -10 seconds. This should clear the message. Hope this helps.
May 25, 2008 | Viking DCWH Kitchen Hood
KitchenAid Architect® II KWCU405SSS Stainless Steel Kitchen Hood Logo
501 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
