Question about Samsung Lands Phones
When trying to charge samsung sph-m320 phone display says no battery hooked up when there is a battery in phone. It is a replacement battery from a reputable reseller.
  • Samsung Master
  • 6,771 Answers
Check to make sure the battery is hooked up correctly and it is properly seated. If this fails then it indicates the detection circuits in the phone are not functioning, a new replacement is recommended.
Posted on Jan 01, 2011
  • charlescalve Jan 01, 2011
    The original Batt works properly with the charger in the phone , the Batt after a year is just getting a bit shorter in life. I order another Batt and that is the Batt which is acting up. I have changed it twice now and still same problem. I guess I need an original Samsung Batt. The replacement Batt was order form a Cell Phone Batt reseller.
  • John Cunningham Jan 01, 2011
    If this is a aftermarket battery then it would explain the problem, I have found the specifications do not match up with the genuine battery in most cases and the item will not work. I have come across similar situations and had to go genuine.
Samsung m320 not charging solution
Hi
I have found a manual for your phone here:
http://downloadcenter.samsung.com/content/UM/200905/20090512220605515/sprint_m320_ug_english.pdf
and around page 16 it mentions the "charger/accessories jack". Most phones will not only charge using the mains charger, but also from a USB socket on a computer. Have you tried this.
If you have then it is likely that either connections inside the phone are not working properly or even that the battery has come to the end of life. You could try removing and carefully reseating the battery to see if this helps. Also try using a multimeter (make sure it is set to the correct voltage range) to see if the charger s registering a voltage at the output plug. If it isn't a replacement charger may solve your problem.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Mar 07, 2015 | Samsung M320 Cell Phone
M320 manual
http://www.manualowl.com/m/Samsung/SPH-M320/Manual/136315
Aug 22, 2011 | Samsung Cell Phones
PHONE DOES NOT HOLD A CHARGE, HAVE TO CHARGE EVERYDAY
If your phone is not holding a charge unfortunately you will need to get a battery replacement for it. If the phone is still under warranty you can contact Samsung directly for a replacement free of charge. If not, you may look for a new battery on sites such as Ebay or Newegg.com
Click here for samsung support
Regards,
G33k
May 12, 2011 | Samsung M320 Cell Phone
WHERE DO I BUY A SAMSUNG M320
http://www.samsung.com/us/mobile/cell-phones/SPH-M320ZSASPR-buy go here type in your zip code and a list of local retailers should pop up
Feb 03, 2011 | Samsung M320 Cell Phone
How did i activate my prepaid virginmoble samsung SPH-m320 cell phone
you can activate them online at www.virginmobileusa.com , or by calling virgin mobile at 1-888-322-1122
Nov 08, 2009 | Samsung Cell Phones
How to activate speaker phone on samsung model sph-m320. don't understand manual an have had no success in using speaker phone mode.
While the phone is in use, press the options key (the right soft key ....) and select 2 for speakerphone.
Nov 04, 2009 | Cell Phones
Samsung M320 wont pair with ilove i316 bluetooth
Try removing the battery and re-pairing after reinstalling the battery and turning on the Samsung M320.
I've written a short article on other bluetooth troubleshooting here: http://yourmonstersofmobile.com/how_to_for_cell_phones/pairing_your_bluetooth.html
Aug 09, 2009 | Samsung M320 Cell Phone
Samsung sgh m620 wont turn on
you hold the power button and the reset button for 10 to 15 seconds and it might turn on. i tried it and it turned on again :) (might work)
Jun 13, 2009 | Samsung UpStage SPH-m620 Cellular Phone
Charging the battery on Samsung Upstage sph-m620.
Well if it's new, then I would take it back to the store from where you bought it. It will be under warranty so, if something is wrong you should be able to get it swapped out with a working one.
Sep 12, 2008 | Samsung UpStage SPH-m620 Cellular Phone
SAMSUNG SPH-a620/VGA1000 = Won't power on at all!
ya try wit another battery it will surely work ....................
Feb 09, 2008 | Samsung SPH-a620/VGA1000
Lands Phones Logo
123 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
