Question about GE WBSR3140DW Top Load Washer
I am finding oil under my washer. - GE WBSR3140DW Top Load Washer
    President:
  • 2,468 Answers
Your transmissions lower oil seal is leaking and needs to be replaced,if the top seal goes,you will start to see oil droplets on your clothes when washed and this is called "wash-back"
Posted on Jan 01, 2011
Oil leak under machine, how do you tell if pump needs more oil
Oil is leaking from the engine. Pump does not have oil in it.
Sep 01, 2016 | Campbell Hausfeld 2500 Psi, 2.4 Gpm,...
Oil leak found under washer. Cannot tell where this is coming from or what cycle. Washing machine still seems to be working okay.
the most likely cause if the oil looks like motor oil that you put in your car but only thicker,is that it is leaking from the transmission which is very common in ge washers the oil is in the transmission to lube the gears which make the machine agitate
to be sure you could remove the front panel and would see alot of oil in the base frame
to remove the panel place a screwdriver between the panel and top and feel around and find 2 clips (one on each side) press on those clips while pulling the panel out
Jul 19, 2011 | GE WBSR3140DW Top Load Washer
Oil is leaking from under washing machine. Looks like motor oil but has no odor. Is this fixable and if so, approx. how much would it cost ?
The only device holding oil under your washer is the transmission. If your washer still has agitate and spin cycles the transmission has not failed but being that there is a leak it will fail soon. Depending on the washer a transmission can be from about 180.00 to 230.00 if you buy the part yourself and do your own labor. If you feel like wrestling with it the front cabinet is held on with two clips under the control panel.
Jul 18, 2011 | Maytag Washing Machines
How do you change the oil on a 1985honda aspencade goldwing?
Center stand the motorcycle.First place your pan under the oil filter cover under the front right corner of the machine. Using a six point socket loosen the filter cover bolt and remove the cover. Dump out the oil in the cover being careful to save the spring and the washer that is stuck to the filter.Many Goldwings have lost there washer in a previous oil change , if lost replace the washer. If you desire change the o-ring on the bolt and the o-ring on the cover. Put the bolt back into the cover and place the spring first over the bolt, then the washer, then the filter , so the spring is pushing the filter against the engine. Put the new filter onto the motorcycle and snug up the cover bolt just enough so the oil wont leak out. Do Not Over Tighten The Cover Bolt. Now place the pan under the right rear corner of the motor. You will find a horizontal bolt near the bottom right rear corner of the main block of the motor. It will have an aluminum or copper sealing washer. Take off the bolt and let the oil drain out. When the oil is finished draining , put the bolt back in with a new sealing washer , if needed , and snug up the bolt just enough so that it does not leak or come out. Again do not over tighten the bolt. Now pour in the new oil through the dipstick hole. Be sure you use JASO MA certified motorcycle oil. You will need 4 quarts but you may have a partial quart left over. The quantity is something between 3.4 and 4 quarts. Run the bike and double check the oil level with your dipstick so you do not over fill.
Sep 12, 2010 | 1985 Honda GL 1200 Aspencade Gold Wing
Where is the oil pan on a hyundai elantra 2002 GT?
Rule of thumb; if you can't find the oil pan then you do NOT have the skill it takes to change the oil!
Jul 17, 2009 | 2004 Hyundai Elantra
Oil on the floor under the washer
The gear case you are referring to is actually the transmission, and yes this is not a good sign. The seal has gone out. its usually cheaper to get another washer than repairing the old one. However if you would rather repair this one then i would try to shop around and find the best bargain.
Jun 14, 2009 | Kenmore 22622 Top Load Washer
My washer is leaking grease or oil on the floor under the machine
Hello and welcome
You said, My GE washer is leaking a tan colored oil underneath the unit. I suspect it's the gear case leaking. How difficult is it to replace the gasket or seal. I like to fix things and have tools. If the gear oil is leaking this usually means the transmission is shot and on it's way out. It is not cost efficient to have it replaced. 99.9 % of the time you throw it out and buy a new washer.
For the cost of the Transmission and the labor.
you can buy a new washer.
How old is the washer ?
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Feb 09, 2009 | GE WBSE2090A Top Load Washer
Oil on floor under washer
Oil is generally not a good sign. It means that the tranny seal is blown OR it means that the tub seal is bad which allows water to enter the tranny (water is heavier than oil... if water gets into the tranny it will displace the oil and force the oil out)
This being a GE? I'd wager that a tranny job is in order. If the machine is less than 5 years old it's under warranty so you'd call GE at 1-800-GE CARES. If it's more than 5 years old? Your washer is no more than a boat anchor. Get a new washer, preferably a Whirlpool. The repair cost for a new tranny will out-weigh the value of the machine.
Hope this helps.
Mar 23, 2008 | Kenmore 22642 Top Load Washer
Kenmore washer
If your washer is not spinning fast enough, or barely spinning at all, this is usually a symptom of any one or all of the following: 1. Bad gearcase (transmission). 2. Bad basket drive, with which the transmission couples to under the agitator. 3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive. Usually a tell tale sign of a gearcase beginning to fail is the sign of an amber colored oil coated under the washer or inside the casing. I said, "usually". It doesn't always happen, but if you notice any signs of oil, the gearcase is shot. The basket drive and clutch assemblies are harder to diagnose and require some disassembly of the washer and the removal of the gearcase to inspect. Let me know if this helps.
Aug 01, 2007 | Kenmore 22642 Top Load Washer
Oil on floor underneath washer
jeffnew The oil which you see on the floor is coming from the gear case. The gear case is not repairable and it has to be replaced. If your washer is less than 1 year old do not wait and call Whirlpool - it is under full warranty. If your washer is between 1 to 5 years old, then the part is still under limited manufacturer warranty but you are liable for any trip and labor charges. It could be much over $200.00. If you are handy and willing to save money, you can buy the part for less than $150.00 and replace it yourself. In that case, I can find the best deal for you and help you with step by step instructions. Gendos...post back
Feb 09, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
GE WBSR3140DW Top Load Washer Logo
115 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
