Question about Neff Ovens
Do you need electrician to install a neff oven.
    Problem Solver:
  • 13 Answers
From a legal standpoint, it depends on where you live. Some jurisdictions require that only licensed, insured tradespeople ,complete with permits and inspections, can do any electrical work. Others allow a homeowner to do basic "maintenance type" jobs themselves, such as changing light fixtures, switches, and even installing new appliances. If you have to install a new breaker, new branch wiring, receptacles etc., you will likely need the services of a professional. Another consideration is that if the installation causes a loss down the road, fire,or injury, your insurance carrier may abandon you! Your best bet is to call your local Inspection Authority, and most appliance vendors will reccomend good tradespeople in your area. I hope this is helpful, Rob.
Posted on Jan 01, 2011
We want to buy a Neff bu-in double oven which needs a 20 amp supply (hard-wired).Our old existing oven is running on a 30 amp supply apparently. Will we have problems when the new Neff is fitted?
The breaker could be changed from 30a to 20a. A 30amp breaker will run the unit but you will have less/no protection since the oven will pull 10 extra amps before it trips which could totally fry your oven depending on the failure.
Re-check the wording to see if it says 'minimum' 20amp breaker or if it indicates 20amp breaker only. If it's minimum 20amp I'd run it.
If it says 20amp only, I'd change the breaker. The existing wiring and outlet will be OK, if the plug-in is the same.
Get an electrician to change the breaker. You should really know what you are doing before you try it yourself.
Sep 16, 2017 | Neff Ovens
Neff installation manual
There are a number of NEFF oven install manuals here. You will need your model number to get the specific one you are looking for at the link:
http://www.manualslib.com/manual/455223/Neff-S5443x2gb.html
Aug 20, 2014 | Ovens
Neff 1031 2
The heating element(s) may have shorted.
Apr 13, 2017 | Ovens
We bought a discounted display model Neff single oven from Comet and have booked an electrician to wire it in however there don't appear to be any cables coming out of the back of the cooker so how is the...
He will probably hard wire it from the terminal block inside the back panel of the oven into the cooker switch or outlet plate on the wall.(providing there is one, if not he will have to wire it back to the main fusebox) .
Dec 17, 2010 | Neff Ovens
MY NEFF DOUBLE OVEN IS ABOUT 8 YEARS OLD I HAVE CHANGED ELEMENT 2 OR 3 TIMES ONE RECENTLEY 2MTHS AGO NOW OVEN IS STILL TRIPPING OUT REGULARY ANY SUGGESTIONS PLEASE HAVE ALSO CHANGED RCD AND HAD ELECTRICIAN...
it sounds to me that the fan is not working properly. as the oven gets older the fans become weaker and then doesn't blow air over the element at a rate that can the temp down enough..
regards
Richard Saupe
http://www.saupe.co.uk
Oven Specialist
Mar 02, 2010 | Neff U1721 Double circotherm Electric Oven
Fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Dec 19, 2008 | Neff U1721 Double circotherm Electric Oven
Looking for installation instructions for a Neff B1691 oven
Neff have some downloadable installation instructions at www.neff.co.uk select neff owners, then customer service, this opens a new window which has instruction manuals as an option, select this and then enter an E number for the model ( i tried B1664) a similar single oven and this brought up a pdf file. At the end p67 it gives cable sizes and types and connection details which should give you what you need.
Please remember to rate this solution.
Dec 08, 2008 | Neff B1691 Single circotherm super...
Neff Oven
its your NEW oven, id call the manufacture for clarification!!
Feb 24, 2008 | Ovens
Ovens Logo
100 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
