I am trying to get some photos off an old computer running Windows 98. I have no CD burner only a couple of USB slots in the back. However when I put a USB Key in the back it does not recognise the key. I have tried downloading a couple of windows 98 drivers but had no luck in getting them to work with this key. The key is a busbi 2gb. Is there a download that works well. Any other advice would be welcome. Lester
    President:
  • 1,851 Answers
You have absolutely right, the USB drives are no plug and play for win98. The fist idea is to try with these drivers:
Busbi drivers case1, Busbi drivers case 2, General use win 98.
I hope that you will solve your problem with these drivers.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Jan 01, 2011
    Problem Solver:
  • 17 Answers
Ok the file system on windows 98 is called FAT, the file system on newer cmputers is called NTFS, It is forward compatibility but not backword. You need to put in a USB flash Drive also called a thumb drive or stick drive into the win98 machine and check for harware changes using these suggestion.
1. insert the flash drive into usb port
2. right click on "My Computer" > Manage - The Computer Management window popsup.
3. Select Disk Management
4. Locate your Flash Drive at the bottom where it starts with "Disk 0" which is your Hard Drive.
5. Your Flash Drive should say something like "Disk 1, removable", to the right it should have a blue line which means it's a primary partition.
6. If it has a Black line, then it means that the Flash Drive has not been partitioned. To fix this do this:
7. Right click on the black line. It should give you an option to partion it.
8. Go ahead and partition it to FAT or NTFS which ever option you can get or want.
9. Once it is finished, then you will be able to read and write from the Flash Drive.
Let me know if it does not work or if you are having problems.
How do I save my pictures to a disk? Also in microsoft word.. how do I save data to a disk?
click start all programs accessories open windows explorer my computer you should see your drive click to open it from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to scan disc then drop them hope this helps
example on how to safe photo's or data to a usb drive
click start all programs accessories open windows explorer navigate to your photos
right click on the photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photos to your usb drive then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps
Aug 26, 2011 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
I have a hp pavilion 6370Z. i lost my windows 98 CD, and my hard drive was formatted. When i try to boot the computer it just says "invalid system disc replace the disc, and then press any key."...
You can dump the windows98 setup to your usb flash drive using wintoflash software and boot your system using usb flash drive. Proceed with the installation steps for win98.
Regards,
Sreejith
Aug 12, 2011 | Microsoft Windows 98 for PC
My memorex 98241 has an sd card slot, can i bypass the desktop computer and burn photos direct from card to disc.
Hello, davidduchnow.
Sadly, the sdcard slot included on the drive is just that-a slot. There is no way to burn files and photos directly from the sdcard slot to a DVD. You must have the drive hooked up to a computer through the USB 2.0 cable and manually move them over.
Sorry to be the bearer of bad news, but there is no way around this.
Thanks for posting.
~Q
May 04, 2011 | Memorex 98241 24x External Dvd Burner...
I need to remove some photos from an old computer. Windows 98;. Is not able to be connected to wireless internet. I bought a Cruzer Blade USB Flash Drive 4 gb. Will not work. As I cannot download a...
If the Windows 98 computer does not have a USB port and you cannot copy the photos onto a floppy disk or burn the photos to a CD then the only option is the following.
Remove the hard disk and connect it to a USB hard drive adapter and then plug this into a USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and copy your photos to this computer or to a USB flash drive.
Oct 07, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Can't load my burner
The CD Burner drive is compatible with your Windows XP the software version is where the problem is. You need to get an updated version of the burner program, something like Nero burning ROM or Roxie EZ CD creator.
Buddy
Corporate Computer
May 15, 2010 | Acer (99.B0112.102) CD-RW Burner
Can't get photos out of old pc
Since it is a 98, you can use a usb thumb drive, but you'll have to install the driver that comes with the drive. You could also use the floppy drive if it has one. You might have to use several if there's a lot of pictures.
Hope this helps!
Dec 28, 2008 | Microsoft Windows 98 for PC
Unconected old 98 pc has no cd burner and i want a program for it to copy photos etc so i can put them into my laptop.I will not be using my 98 pc any-more when i have got out all my important stuff.
welcome to fixya
ya you can use a memory stick that hooks in the usb port to down load the stuff you need and yes it should work
i hope this helps you out have a good day
Jul 28, 2008 | Computers & Internet
Old 95 computer
well you have to get the cd you may have to buy it or get that from somebody
Dec 27, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Need driver for this camera for windows 98
debra_s,
You'll have to explain what you want to do? If you want to download your images, you don't need a driver, just attach a Windows 98 compatible card reader to your USB port and download your pictures to your favorite photo manager. You should be able to attach your camera via USB, and if the USB drivers detect the camera's disk, then a new drive will appear your My Computer.
If you have Windows 98 Second Edition, you should be set to go, if you have Windows 98 First Edition (where it doesn't say Second Edition in the My Computer properties), you'll have a tougher time with the USB connections. It would be best to upgrade your machine, or find the Windows 98 SE upgrade from a friend.
The CD that came with the camera will have the necessary software for Windows 98 SE.
What have you tried to do? What isn't working? Let me know some details and I'll help you out.
Hope these ideas help. Clarify some things and I can give you a more narrow answer.
Nov 14, 2007 | Nikon D40x Digital Camera
D40 Zoom and Camedia Software
Camedia software leaves a lot to be desired. I prefer to use a USB media reader and Google's excellent Picasa software to manage my photos.
Mar 31, 2017 | Olympus Camedia D-40 Zoom Digital Camera
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
