Question about Dayton (1UM39) Floor / Box Fan
I opened a stand fan when it stoped working, I checked what coul be the problem but couldnt find any. But when you switch on you can hear the sound of the motor but it wont spin the rod what could be the problem?
    Sergeant:
    Champion:
  • 342 Answers
The problem could be a bad capacitor and you can email me at custserv.compuparts@gmail.com and i will tell you and send you a picture of the Capacitor but they are ususally a round or square that has two wires coming out of it. if you replace that the fan should work fine
Posted on Jan 01, 2011
Our hunter fan is less than 2 years old. the fan works fine but suddenly the light fixture will not work. changing the bulbs did not help
Do you have a separate wall switch controlling the lights that may be turned off and possibly not realize it? If all lights just stoped working and you are sure that their is no switch turned off controlling the lights, then you likely have a bad fan controller inside the fan housing, or a wire has come loose. If you are electrically handy, open the fan housing and check to see if you have power to the fan light wire. All of the lights going out at once sounds like a wire possibly a neutral (white) wire may have a bad connection.
Feb 07, 2017 | Hunter Dryers
When I turn the system on for cooling, everything sounds likes its running properly, but no air comes out of the house vents. The capacitor is good, fan comes on, coils are getting cold. Could it be the...
Its possible but you might try a little diagnostics first. Put your thermostat in the off position and the fan switch in the auto position. Make sure the switch on the air handler inside is on. Now have someone stand by the blower while you switch the fan switch back and forth from auto to on. If the person at the blower hears a clicking sound from inside the blower cabinet you probably have a bad motor. But if you hear nothing it probably means you don't have power. Check the blower door to make sure its tight and the safety switch is depressed. The wall switch should be tested. Don't have any easy ways to check for power without a volt meter. Hope this helps good luck.
Aug 18, 2013 | Goodman Manufacturing Goodman GPH1530M41...
Onkyo tx-ds989 goes to stand by mode just playing for 3 second ... rest every thing is ok I just hear a click sound (relay switch off) and it goes to stand by mode again switch it on .... same thing...
Check the speaker wiring on back that it is not shorting against one another, output ic's may have bad solder connections and should be checked carefully.
May 28, 2012 | Onkyo Audio Players & Recorders
My hp ml370 g5 server is not booting when i switch it on i only hear the high sounds of the fans with out stoping till i fed up and power off it manulay . this problem used to happens from time to time...
my hp ml370 g5 server is not booting when i switch it on i only hear the high sounds of the fans with out stoping till i fed up and power off it manulay .
Jun 27, 2011 | HP ProLiant ML370 G5 Server
My computer starts and try to booth up but it will not finish booting up what coul be the problem
try taking your ram out and put it back in
if it dont work see if the fan is working
prob over heating see if fan has dust stoping air flow
Feb 09, 2010 | Dell Latitude D500 Notebook
The heater fan stoped workin
Check the blower relay,and the blower switch.
Feb 06, 2010 | 2003 Kia Spectra
Stoped working
it sound like you have a problem with the evaporator fan. check inside to see if you feel air going though the air vents. You should be able to even hear the fan turning, if not there's your problem.
Sep 08, 2009 | Avanti BCA327B 3.2 Cu. Ft. Counterhigh All...
Left side fan is not working
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing. A little oil inside teh motor and several revolutions later might get some relief until a new motor is installed.
Jun 13, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton beach water cooler is not cooling
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing. A little oil inside the motor and several revolutions later might get some relief until a new motor is installed.
Jun 07, 2008 | Hamilton Beach Water Cooler with Storage...
Dayton (1UM39) Floor / Box Fan Logo
95 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
