Question about Maytag Neptune MDE7500AY Electric Dryer
We have a Maytag Electric dryer that is not heating up totally. Removed the vent tube and seemed to help but I check the Ohm's on the thermometer and was working. Tsted the col for ohms and at the RX1 setting it was at approx 2 - 3 ohms. Does this mean it is working?
  • 312 Answers
Hi, If your resistance is 2-3 Ohms, then your element is on it's way out . It needs to be replaced. The resistance should be in the range of 7-20 Ohms on a 240 Volt dryer heating element with the multimeter set at RX1. Good work finding that.
There are some additional reasons a dryer will not dry, have no heat, or cause the element to burn out prematurely.
1 If the exhaust vent run distance is too long. i.e. more that 15 feet the heating element life will be shortened Why? Because in a long vent run the vapor from the most clothes condenses on the sides of the vent hose and lint sticks to it. This lint accumulates and reduces the internal diameter of the hose. This increases air friction and the element runs at a higher temperature, etc. etc.
Solution: Clean the vent system out, or replace with a shorter system, if possible. There is an accessory fan available that can be installed that allow you to have a very long exhaust vent run. See Link
http://www.hvacquick.com/products/residential/Dryer-boosting/dryer-booster-fans/fantech-dryer-boosters?utm_source=google&utm_medium=cpc&utm_term=dryerboost&utm_campaign=fantech
2 Exhaust vent hose folded or squeezed almost or completely shut at back of dryer. This ocures when the machine is too close to the wall pinching the hose. No air carrying the moisture leave the dryer.
It can get hot and after the cycle is done. The clothes are still wet. Solution: Pull out dryer and unfold hose.
NOTE:
Don't use a dryer without a vent hose attached. The dryer will pull the hot air with lint in it back into the machine. Over a period of time this lint can accumulate in the machine and cause a "lint fire" Lint fires inside a dryer sometimes turn into house fires.
Hope this helps,
Happy New Year
Mark
Posted on Jan 01, 2011
No heat in the dryer. Everything else seems fine. Is it the element, or am I missing something? Where can I get schematics? Samsung DV328AEW
Hi, I experienced the same problem with my Maytag electric dryer. My problem was finally resolved when I inspected the vent tube/pipe and found a mouse nest. Once I removed this mouse next, my electric dryer worked perfectly. In the winter time, mice love nice warm places and a dryer's vent pipe is very attractive. Just a thought. Good Luck! Please remember to rate my solution. Thanks!
Jan 18, 2011 | Samsung 7.3 Cu. Ft. Super Capacity...
I have a ldg382 gas dryer. The dryer runs and heats a little, and the timer will not advance, stays in same position.
disconnect vent tube, run dryer as it shall work now. I would guess restricted vent tube. Good Luck Tim
Jan 16, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
Jan 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
WONT HEAT, DRYER WILL TURN BUT WONT HEAT UP.
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 13, 2009 | Maytag PYE2300AY Electric Dryer
Electric Maytag Neptune Dryer not heating up.
If the dryer won't heat up, the problem is typically either a blown thermal fuse or a faulty heating element. The thermal fuse is located just inside the back of the dryer on or near the exhaust duct. It is about one inch long. The thermal fuse and heating element can be tested using an ohm meter or multimeter. These components should have continuity. If either does not, that component is faulty. There is no telling if the moving around of the machine caused the problem or if the timing of the problem was coincidental. Sure hope this helps ya and best wishes.
Jul 21, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer takes forever to dry clothes
This is a classic example of a clogged vent tube. Everyone cleans the lint trap, but seldom checks the tube that connects the dryer's output to the outdoors.
The tube should be removed and replaced if it is the flexible plastic type. The flexible metal tube can be used if you can clean it easily enough. The best tube to use is the sheep metal type. It can be easily cleaned and is very durable. Be sure to pay particular attention to turns or right angles of the tube - nearly always at the rear of the dryer - before it is directed away. Make sure the entire length is clear including the cap at the outside end - be it in the wall or roof.
Of course, if the heat isn't as hot as it used to be, there could be another heat source (gas or electric - or even both) related issue too. I'm betting that the vent has never been inspected.
Apr 07, 2009 | Maytag MDG6000 Dryer
Maytag dryer model # SDE3606AWY HEATS UP TUMBLE clothes but does
There is most likely a lint obstruction somewhere in the exhaust. Start by checking the outside vent as often there is an animal screen on it that over time gets caked with stray lint. If that's clear then work backward and check the hose, etc until you either find something or get to the dryer itself. It's possible that in the internal exhaust tubes there's an obstruction as well so if you don't find anything in the external tube you will need to disassemble and have a look inside those internal exuast tubes/ports. If it's inside then do it soon as there's clearly a risk of fire if there's a wad of lint somewhere inside where it shouldn't be.
The mother of a friend at work had this issue - her clothes took HOURS to dry. Her animal screen had several inches thick layer of lint. Once that was removed the dryer dried like new.
Mar 29, 2009 | Maytag SDE3606A Electric Dryer
Maytag dyrer mdg6200aww the heating systwm does not stay on
Remove the vent from the rear of the dryer.
With no clothes in the dryer and the dryer set for hi heat run the dryer several minutes.
With a accurate thermometer check the exhaust vent temperature.
It should be 135 to 160 degrees.
If it is, you are OK. Just need to clean your vent and connecting tubing.
If not, replace your gas valve coils.
Mar 04, 2009 | Dryers
Whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Maytag Neptune MDE7500AY Electric Dryer Logo
95 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
