huh? what did you,,do , to cause that.? did you try to flash this system? flash new bios? form a full question: like this I did x and got y. how do , flash back my bios. or how do i get new bios.or how to i use BIOS to do x/?
you need to reinstall your printer in your new pc and try only full setup download it from here and just put your operation system and language you want
Check simple things first - as soon as engine dies, remove gas cap and attempt to restart. If successful, the vent is blocked, causing a vacuum to form in the tank. Effect will be more pronounced when tank is full.
Sff stands for 'small form factor'. A PC that doesn't take conventionally sized pci expansion cards is sff. The hp 5000 dt is made in both a full sized and sff form factor.
But I think you can figure it out now. I have faith in you.
To restore to factory settings when you hit the start button the firstscreen that appears has the HP Symbol in the center of the screen. Whenthis appears hit the F11 key. Then follow the on screen instructions.It will offer you to either restore to last saved point or to restoreto factory settings. There are a few other options offered, like do youwant to back up you files etc.
kindly download this manual it will help u keep running ur system
thisCompaq D530 small form factor pc is only able to run a processor to 3.2ghz @ 800mhz front side bus ( FSB )
the full spec and upgrade options are on the link below. [email protected]
