Question about Sony Playstation 3 (PS3) Console
I usually play my ps3 in a TV that has no HDMI, then I just upgraded my ps3 to Version 3.41, when i play my ps3 in my TV that has no HDMI, the ps3 unit turns on but there are no display on the TV screen, can i ask for help? thanks.
Hi, turn off the ps3, then hold the power button until a screen comes up asking you if you can see the screen (this resets the video mode). this should fix your problem :)
Posted on Mar 18, 2011
I have a PS3 hooked up via hdmi. The screen goes black for 1 second then comes back during game play. It doesn't do this when hooked up through component connections. I replaced the hdmi cable and...
Ur tv is on 3D mode setup probally,i'm wright?Yes?Set the tv it back to 2D mode,should stop the tv delaying 1 sec. black out intervolt should stop happening.Because ur are not using a 3D PS3 machine ur are using an PS3 2D a normal system.
Aug 08, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
I have an Onkyo TX-SR605 , I have my ps3 connected via hdmi and from the amp to a 3d tv via hdmi . when i am connecting through the amp the PS3 does not recognise i have a 3d TV and will not play 3d Movies...
No but you may be able to help me. I have the same amp and ps3. I have HDMI leads from both but cannot get sound or picture. I do get the set up menu which means it recognises the HDMI lead. How is yours set up ?
Jan 25, 2011 | Onkyo TX-SR605 Receiver
I changed my HDMI cables to get my PS3 to play
You need to set your HDMI, resolution down, on PS3 FIRST, using composite, or component hookup, to the TV FIRST, Turn OFF, but DO NOT select HDMI, leave it on, Composite, or Component, when finished setup the TV, the turn it off, leave off, Then connect up PS3, power on, NOW turn on the TV, select HDMI, Change PS3 to HDIM, now it should appear. Sometimes you have to "Reset" the TV, by tuning it on & off.
Apr 24, 2010 | Vizio L32 32 in. LCD HDTV
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
I have my PS3 plugged into my RX-V365 via HDMI then i have my RX-V365 plugged into my Sony Bravia, the problem is i get no Audio through the HDMI input on my Amp but it still comes through the TV how can i...
Run optical or digital coaxial from your PS3 to the receiver and HDMI from the PS3 directly to the TV. Your receiver's version of HDMI will not work, it's 1.1 and cannot be updated. That's the fix, if you want more info on HDMI problems google HDMI issues or problems and you will find thousands of posts and forums on this issue. Short answer though is, you either need a receiver with version 1.3b HDMI or run optical or digital coaxial for audio to your receiver. Hope this helps
Dec 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
When playing ps3 picture will black out
If your running HDMI, run your HDMI directly to the TV and use digital coaxial or optical for audio to the receiver. Your firmware in the receiver is not compatable with all the new RIAA audio and video codecs in version 1.3b your receiver is 1.1 or 1.2 and is not upgradeable. It's not Yamaha or any other MFG's problem it's the recording industry and copyright protection that's messing up HDMI. Hope this helps
Oct 17, 2009 | Yamaha HTR-6030 Receiver
Samsung DLP TV and PS3 Problem
Would you please read the manual of TV & PS3 for HDMI cable's
version.
If you match that version, can play.
Dec 27, 2008 | Samsung DLP HL-P5663W 56" TV
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Green screen
I am a TV repair technician and what you are experiencing with your plasma and PS3 is a HDMI compatibility problem. The Philips plasma and the PS3 electronic handshaking (EDID) are not right. This happens alot with an older version of HDMI like 1.1(Philips Plasma) and a newer version of HDMI 1.3 (PS3). A tv firmware or PS3 firmware update will not resolve the problem. I would recommend using the HD component video cables and that should work just fine for playing High Definition BluRay movies.
Oct 05, 2008 | Philips 42PF9966 42 in. HD-Ready Plasma...
Sony Playstation 3 (PS3) Console Logo
44 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
