Question about Technics SL-BD22 Turntable
When i start my sl-bd22 turntable is making a noise as the plateau turns......how can I fix that? Other than that noise, which is a bit annoying, it is working good
  • Technics Master
  • 5,126 Answers
First check the belt it could be causing the problem (I assuming it's a belt drive as it looks like one). Next check for obstructions. If you lift of the matt you should get a view inside. Apply Silcone Grease to the spindle area. If still no luck, remove the bottom cover to gain a better view and see what's what. Again if you think it needs a touch of grease then apply it.
Posted on Jan 05, 2011
  • 3 Answers
This is a very common complaint about this unit but it is not a problem. The motor is run by a series of DC pulses. The motor is housed in a rubber holder/mount. As the units got older the rubber got a bit harder and more of the pulsing noise is transmitted to the frame. It is generally low and I never heard of any of this affecting the playing of the sound coming out of the turntable. Don't worry about it.
Posted on Nov 21, 2011
How do I find a Technics SL-BD22 grounding wire?
A grounding wire is just a piece of wire connected to an earth point on the deck, connecting to an earth point say on a radiator pipe. There's nothing special about this wire any old piece will do. You only need it if you get a hum noise when the turntable is connected to the amp.
Jul 18, 2014 | Technics Audio Players & Recorders
What size belt on the SL-Bd22
Just purchased a belt for my SL-BD22 from Vintage Audo (Audio?). The belt size is 23.6 X .180 X .025 inches. Their part number for this belt is:B00926DJ74. Hope this helps.
Oct 21, 2012 | Technics SL-BD22 Turntable
After 14 years my Technics SL-BD22 Turntable has a disfunction The electric motor turns slow.
Your turntable is probably belt driven so most likely motor is turning okay but belt is slipping.
They are easy to change, first just lift rubber mat on platter and you should be able to see the belt through a access hole in the platter.
Feb 28, 2011 | Technics SL-BD22 Turntable
I had not used my turntable for about five years due to no needle. Found a needle and played two LPs, then on the third one, it just did not move or work at all. It lit up but just acted like it had no...
The low grinding noise could be the motor spinning with "no load" i.e the belt has snapped or fallen off due to being perished.
Lift the platter to refit the belt and or replace it if required.
Jul 23, 2010 | Technics SL-BD22 Turntable
I just purchased a Technics SL-BD22 turntable and it came without the ground wire. Is there anywhere I can purchase this proprietary part?
just get any small speaker wire and use that as your ground , attach that to the reciever you are using
Jan 16, 2010 | Technics SL-BD22 Turntable
Turning slowly, then stops
Based on the experiences, it sounds like it's something on the main board. Perhaps one or multiple resistors failing, not allowing the correct current to hit the motor.
Unfortunately, not an easy fix. I would suggest contacting a service center for assistance.
- OPTiC
Electronic Repairs & Service
A DJ Pro Audio Co.
Nov 24, 2008 | Technics SL-BD22 Turntable
Turntable grinds to a halt.
The Technics SL-BD22 is a belt driven turntable. It is most likely possible that the belt wore off, wore down, or could have spun off. The platter should have 2 holes in it. One of them should alow you to see, and replace the belt. YOu can lift the platter off the turntable via those two holes. MAKE SURE IT IS TURNED OFF AND UNPLUGGED......
You can find a replacement @
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES-Drive_Belts/c271_272_278_398/index.html
And the part should come with instructions. Those guys are very thorough.
Keep me posted.
Nov 05, 2007 | Technics SL-BD22 Turntable
Technics SL-BD22 Turntable Logo
353 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
