Question about Hotpoint Dryers
Makes a metal scraping noise when rotating clocwise
  • Hotpoint Master
  • 8,220 Answers
You need to open up the dryer and do some checking:makes a metal scraping noise - themobilian_642.jpg
Unplug the dryer and pop the top then check the glides. Next remove the drum and check the rear bearingthemobilian_643.jpgthemobilian_6makes a metal scraping noise - themobilian_645.jpgthemobilian_646.jpgthemobilian_3.jpeg
More repair photos and how that belt goes back HERE
Posted on Jan 01, 2011
What coul possbly cause scrubbing nose at right from wheel on 2004 dodge Dakota
Most likely is a problem with the brakes like worn out disk brake pads now making metal to metal dragging between the disk and caliper. take it to a brake shop and have it checked, because it is unsafe to drive if it is this issue.
Sep 05, 2015 | Dodge Cars & Trucks
My 2004 saab linear is making a scraping noise when I accelerate from 0-20mph then stops and also makes a scraping noise whem I press semi hard on the brake what could this be
Disc pads worn down to metal.or foreign body caught between disc and the shield at the rear of disc(pebbles make terrible noises
Jan 29, 2015 | Saab Cars & Trucks
How do I fix squealing and scraping noise in my Kenmore gas dryer 110.74812200?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Sep 21, 2014 | Dryers
Tread pad squeak or scraping noise
Sound like metal rotating in metal, could be 1) roller bearing,2) motor bearing
Proceed with this videos mechanical adjustment:
Dec 12, 2011 | Proform 790T Treadmill
Hi, Thee dryer makes a loud noise during cycle. It starts low, but it seems after each rotation it get louder. Has anyone ever experienced this and are there any solutions. Thanks for any assistance.
Describe the noise. If its a rattling banging noise you could have a broken exhaust fan which is usually attached to the motor, a broken cylinder roller (if your dryer has them) or worn felts. Maybe a noisy pulley. If its more a high pitched squeek it could be your motor or the parts just mentioned. A metal scraping noise could be something like a bra wire caught by the cylinder but I don't see how that can get louder as the rotates. Make sure the belt isn't cracked all over. Worst case scenario is that your motor is on its way out...
Good luck
Aug 29, 2010 | Dryers
I cleaned out my lint tray and after I put it back in, the dryer started making a grinding noise?
Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a squeak.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
May be loose drum slides can cause a metal scraping noise as the drum rotates. For that you'll need to contact Crosley Service Center.
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 02, 2010 | Crosley CDE6000 Electric Dryer
Maytag washer noise
Hello, If its making a loud squeeking/scraping noise, in my maytag that i repaired, the problem was the waterpump. If you turn the washer on it's side, you will see that it has a belt with three pully's on the bottom. One pulley is connected to the waterpump and right where the pulley meets the metal plate it's connected to, there should be a gold2_bing.gif coupling. This coupling sometimes comes loose and scrapes the metal plate on spin cycle (when the pulley is spinning) which causes the scraping/squeeking sound. If this is the case, you will see where the coupling has scraped a groove into the metal plate. The coupling will eventually catch while spinning and break entirely. The cheapest new water pump is $80.
Thanks
May 19, 2010 | Washing Machines
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer making squeeking noise
Check the dryer belt tensioner and pulley assembly. It be wearing out. You'll need to remove the back cover of the dryer to do this. Turn off the gas and/or electric before working on the unit.
Mar 26, 2009 | Maytag MDE9316 Dryer
Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Jun 01, 2007 | Creda W100FW Front Load Washer
Dryers Logo
70 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
