Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Electrolux EL7020A Oxygen 3 dead!
If there is a reset switch on the main body, I don't seem to be able to find it. I hear there is a circuit board that casuse a no power problem. I think I can fix it if I can disassemble it and get to the controller board. Any suggestions?
Thanks
Bill
    Novelist:
  • 97 Answers
There is a board in the back (called the "SUMO board") which has a fuse hardwired to it. Most of the "no go" problems with this machine are related to this.
In order to check it, you'll want to take a thin flat-head screwdriver, and gently pry up the silver panel on the top of the machine. The easiest place to do this is on the side of the panel, as far toward the rear of the machine as possible.
You will then need to remove the 2 Torx screws on the rear panel, and the top body of the machine should then be able to be removed. There are two clips in the bag chamber, directly under the back portion of the bag compartment lid, which can be pressed in to facilitate removal of the back cover.
The sumo board will be sitting directly on the top of the machine, and the fuse in question will be on the right if you are looking at it from the rear of the machine. Unfortunately, if the fuse is blown, you will have to replace the entire circuit board. (Unless you feel very comfortable with soldering a new fuse onto it, which I do not recommend for safety reasons.)
You can also check continuity of the cord reel from here. On the right hand side of the board are two spade terminals leading to wires running down into the cord reel assembly. One black, one white. Checking the continuity between these terminals and the ends of the power supply cord will allow you to determine if the cord reel is providing power to the machine.
Accessing the cord reel will require you to remove the six Torx screws holding the main body to the base. Two of these are on the rear of the machine, and are very deep inside; so you will require a very long-shanked Torx driver to get at these. Two more are inside the bag chamber at the rear, and the other two are on the front handle assembly. This will allow you to lift the main body away from the base, and if you are replacing the cord reel you can pull the wires from the spade terminals and the socket on the sumo board, and feed them back down into the cord reel chamber to remove the old cord reel.
Reassembly is simply a reverse of the previous. Beware, however: getting the cord reel to align is something of a chore, so make sure that you have the retraction system functioning before you put the whole thing back together, or you'll be bummed when you finish reassembly and the cord won't retract.
(I've definitely never done that. Nope. Never.)
Hope that helps, good luck.
-R
Posted on Jul 31, 2008
  • cpwalker403 Sep 05, 2011
    Thank-you very helpful--I saved $$$ by following your instructions. I replaced the fuse for just a couple of bucks. I also "splurged" and bought a fuse holder and installed it ($3.00). Now there will be no soldering necessary if the fuse ever needs to be replaced again. I'm sure the repair bill would have been a new SUMO board ($90.00) plus labor. I just love the internet and folks like you who are willing to share their expertise!
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Posted on Nov 09, 2009
  • 1 more comment
  • brownieking Sep 09, 2011
    Ditto for me. Radio Shack $3 fuse and $4 fuse holder did the trick. The soldering was easy. Just clip off the old fuse as close to the fuse body as possible, leaving the fuse leads still soldered to the board. Then solder the fuse holder wires to those leads. Piece of cake.
  • jrairan
    jrairan Jan 11, 2012
    my fuse looks intact... can it still be bad by sending a signall to the switch to turn off ?
  • shamusj
    shamusj May 25, 2015
    Life saver! I removed the entire fuse and leads and replaced it with a chassis mount fuse holder from Frys electronics. Took a few tries to get it right yet looks and works perfectly. Would have been more simple to replace the board yet very satisfying to DIY and have it up and running again.
Electrolux el7020a brush motor wont run
take the cleaner apart and make sure that the wires are all hooked to the on and off switch that got to the beater bar that is the main part of the problem improper wireing
Mar 22, 2014 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Need to replace the main control board
Your best solution is to call Electrolux Home Care and find your nearest warranty station, even if you are no longer covered.
They will know how to perform this fix conveniently...unless you already have the new SUMO board. If that's the case contact me here, if that's possible, and I'll try to lead you thru the steps.
Nov 09, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Parts manual
VacPartsWhareHouse.com has the most helpful parts manual and schematics for your model vacuum:
Electrolux EL7020A
Mar 15, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Where is the reset button on the oxygen 3 canister?
please see the video: proceed with common sense and repair. God bless you.or go www.electrolux.com go customer support and download your instr. manual and see the reset button.
God bless you
Jul 15, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I'm looking for an electrolux oxygen repair manual
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My EL7020 so call Electrolux!
Check the electrical connections between the hose and the body of the machine, and also the wand connections all the way to the power head. Sometimes a faulty connection can send a false "off" signal back to the main body of the machine, and turn it off; but usually it will restart if that's the case. It sounds like you have a clog somewhere which is tripping your motor's thermal cutout, but you did say there are no clogs... so if you have full suction all the way down to the powerhead that's not the issue. You could have a faulty thermal switch, but I think the likely cause is, as usual; the sumo board.
Good luck. Sorry I didn't have a more concise answer for you.
-R
Dec 06, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Accidentally plugged into 220 volt outlet
The wiring diagram isn't showing a fuse, but there could be one on one of the circuit boards. Maybe the converter is bad. You will just have to take it apart and look it over. Maybe this pic. will help:
Nov 05, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
2,856 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
