Question about Samsung (SD-612SE) Internal DVD Drive
I dont know where to put the jumper in the back for the master setting.
    Problem Solver:
  • 10 Answers
Posted on Jun 05, 2011
I dont know were will i put the jumper to turn my hdd on master
I can tell you where to put it, but your probably better off to go online and search for SAMSUNG JUMPER SETTINGS. They will show you a picture.
Jan 25, 2014 | Samsung SpinPoint SV8004H 80 GB ATA-100...
What happen if i dont put jumper in a hard a hard drive?
If you don't put jumper in harddrive is detects it as cable select means if you connect your harddrive to middle socket of ide cable and then it detects it as slave but if you connect it at the end of ide cable it detects as slave.But make sure that otehr device is not set as master only 1 device is set as master or slave .
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
I NEED TO KNOW HOW TO INSTALL A CD-ROM DRIVE INTO MY E-MACHINE..
Step1 Turn off your computer and unplug. Remove the left and right side panels.
Step2 Remove the covering of the drive bay that you plan to use for your new CD/DVD Drive.
Step3 Set the jumper. This is the most difficult part involved with the installation process. If you only have one drive for your system set your jumper on the back the drive to Master. If you have two or more set it to slave. Consult your drives manual to see a picture of what a master/slave jumper configuration looks like. It is best to have the fastest drive set as the master.
Step4 After you have set the jumpers insert the drive into the empty drive bay you selected.
Step5 Secure your CD/DVD drive to your computers chassis with screws and a screwdriver. Mounting screws are typically included with your drive.
Step6 Locate and connect the required power and IDE cables to the back of the drive. These cables are keyed, meaning they are shaped specifically for that drive. It's impossible to install the wrong cables.
Step7 Put the side panels back on and plug your computer back in. Turn it on and your computer should recognize the new drives. If they are not recognized you may need to install the drivers, which are usually included on a CD that's included with your new drive.
I hope that helps. If you have any more questions, let me know.
Jan 10, 2009 | E-Machines emachines (emachinees) CD-ROM...
No cd included with hard drive, how do i install?
normally you dont need any software to install the HD if its a newer computer (last couple of years) just check your jumper settings, it should show you on the HD where to put the jumper for master / slave.
If your putting it in as a second HD for more space you will want to put the jumper on the back of the drive to "slave" and attach it to the same cable as the hard drive in your computer already.
Jan 02, 2009 | Maxtor Hard Drive
Jumper setting
Put the jumper on J50(the closest set of pins to the IDE connector)
This will set the drive to master, with no pins on it's currently set to slave.
Chris
Oct 21, 2008 | Maxtor DiamondMax Plus 60 (5T040H4) 40.9...
How to set hard drive jumpers
a common hard drive jumper setting if its an ide sata, when you look behind the hard drive, you can see there are 4 places where you can set the jumpers...
there is cable select which you dont havce to put any jumpers at all. there is slave to which you may put 1 jumper there. and there is also master which sometimes is a single drive. any indication should be seen there above the jumpers which is indicated as MA- master, SL- slave CS - cable select.
hope this helps you in some way.
May 04, 2008 | Computers & Internet
Jumper settings
insert the jumper in the first pins from the left insert it verically. For master setting.
Jan 17, 2008 | Computers & Internet
Samsung (SD-612SE) Internal DVD Drive Logo
64 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
