Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I have done a monthly backup on my laptop for more than a year, but this time I'm getting an error message "corrupted file system 0x81000008
    Problem Solver:
  • 17 Answers
Run a check disk on the Drive and select Fix bad sectors.
    Running CHKDSK through the Windows Command Prompt:
  1. Go to the Windows Command Prompt. You can do this by clicking first the Start button and then clicking the Run button. After this, type "cmd" in the Open text box and press Enter.
  2. View the displayed Command Prompt screen.
    If you want CHKDSK to run in read-only mode, type:
    CHKDSK c:
    If you want CHKDSK to fix errors and not to check bad sectors, type:
    CHKDSK c:/f
    and press Enter in the Command Prompt.
    If you want CHKDSK to run thoroughly; that is, fix errors, find bad sectors in your hard drive and recuperate still readable data, type:
    CHKDSK c:/r or
    CHKDSK c:/p and press Enter in the Command Prompt.
  3. Running CHKDSK through My Computer (Windows XP)
  4. 1
    Initialize the properties of the hard drive you want CHKDSK to run. Open My Computer. Right click your mouse on the drive in which you want CHKDSK to run. Click the Properties button and click the Tools tab. In the Error-checking box, click the Check Now button.
  5. 2
    Set up the Check Disk options by checking one or both check boxes displayed. These are labeled "automatically fix file system errors" and "scan for and attempt recovery of bad sectors". If you want CHKDSK to run in read-only mode, do not check either box. After this, click the Start button.
Posted on Jan 01, 2011
Corrupt Windows 7 system files.
You have done everything I would have suggested, at this point a clean install of your operational system is the only real option to remedy this situation.
Mar 12, 2012 | Computers & Internet
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
Won't back up files. Said 'The backup did not
reformat the removable storage device I assume its a thumb drive. go to my computer right click on drive g and select format on the menu, you have 2 choices to format in fat32 or ntfs of course the thumb drive should be formatted in fat32 so select fat or fat32 and do a quick format. that should fix your issue unless its a physical hardware problem with the drive. make sure you remove anything on your g drive that you can access and move to your computer because once its formatted everything will be deleted. after the format, start your backup again.
hope this helps and thanks for using fixa. please rate your experience and feel free to reply with any questions.
May 30, 2011 | Samsung Computers & Internet
While opening the company an error message is showing " File: 'C:/Tally/Data/0001/Tr01324.900' Size;- 3100672 Possition; 3100672 (Done 512)"
THE PROBLEM U R FACING IN TALLY IS THAT THE DATA FILE OF THE COMPANY IS CUR OFT SO TRY TO REPAIR THE DATA FILE OR IF U HAVE A BACKUP RESTORE IT ON THE PROGRAM,ALSO REMBER TO BACKUP EVERY DAY OR WEEKLY AS POSSIBLE
Nov 13, 2010 | Computers & Internet
Though i know i have done backup on acer aspire e571
Your computer operating system is corrupt. Or maybe there is virus on your system that has made it corrupt.
Do you have any anti virus on your system? I will recommend that you try Avira Anti-virus. After you have installed the anti virus, use it to scan your system thoroughly and see if problem will persist.
If problem persist, then you will have to run the recover manager on your system. The recovery manager will help you repair and put your windows back to order, that is, to its factory default state.
Before you carry out the system restore, make sure you backup all your important files.
To do the system restore, click start menu, click all programs, look out for "Back up and recovery manager, click it and follow instructions.
I wish you the best.
Dec 18, 2009 | Acer Aspire 4315 Notebook
Blue screen error 0x00000024 dont have recovery disk
This Stop message, also known as Stop 0x24, indicates that a problem occurred within Ntfs.sys (the driver file that allows the system to read and write to NTFS drives).
Resolving the ProblemDisk Corruption. Corruption in the NTFS file system or bad blocks (sectors) on the hard disk can induce this error. Corrupted SCSI and EIDE drivers can also adversely affect the systems ability to read and write to disk, thus causing the error.
Check Event Viewer for error messages from SCSI and FASTFAT (System Log) or Autochk (Application Log) that might help pinpoint the device or driver that is causing the error. Try disabling any virus scanners, backup programs, or disk defragmenter tools that continually monitor the system. You also need to run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Run Chkdsk /f /r to detect and resolve any file system structural corruption. You must restart the system before the disk scan begins on a system partition. If you cannot start the system due to the error, use the Recovery Console and run Chkdsk /r.
rate me if you think its fixya...
regards,
Dec 06, 2008 | Gateway MX6025 Notebook Computer...
Corrupt File System
Well i guess that either your file system is corrupt or your disk is formatted into a filesystem that it's not supported by the backup programs. I don't really know what filesystem is your disk formatted into but usually the FAT32 and FAT16 are the most failsafe file systems for Windows.
So copy/paste the data you don't want to loose and then go to
My computer -> right click on the drive icon -> format and then choose fat 32. Then try backing up your laptop again.
May 20, 2008 | Western Digital Passport WDXML800UE...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
196 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
