Question about Honeywell Programmable Thermostat Heater
I have an Inter-City Products ( ComfortMaker heat pump-A/C unit that I wanted to install a Honeywell Programmable thermostat. Honeywell Thermostat RTH7400D1008. It has no provision or direction for the "T" wire (the Outdoor anticipator reset ) that is on the original manual thermostat. What to do with that and what does the Outdoor anticipator reset do?
Buffalo12980
  • 625 Answers
SOURCE: installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Posted on Dec 07, 2007
muttandjeff
  • 359 Answers
SOURCE: Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Posted on Oct 26, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 96 Answers
SOURCE: Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Posted on Feb 01, 2009
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Replace a honeywell t822l1000 with a programmable unit
Match the thermostat wires to the letters on the new thermostat terminals R Red Y yellow ETC.
Nov 16, 2014 | Honeywell T827K1009 Mercury Free EconoStat...
The ''Backlit Screen'' won't light. Never has. Honeywell FocusPRO 6000 5-1-1/5-2 Day Programmable Thermostat(heat pump) Any suggestions?
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Heating & Cooling
Room thermostat Honeywell T6360B - gravity hot water, pumped CH
Go to honeywell.com
Mar 02, 2010 | Honeywell Programmable Thermostat Heater
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
After RTH6400 installation heat strip is no longer actuated
http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/Do-It-Yourself/Programmable/5-1-1/Default.htm look at the very last part of thius page and you will see that the particular thermostat does not work for heat pumps tha have auxillary heat. Sorry for being the bearer of bad news but you need to upgrade the selection to make it work right.
Jan 24, 2009 | Honeywell Electronic Programmable...
Oct 23, 2008 | Honeywell Electronic Programmable...
Installing a honeywell CM900 wireless programmable thermostat
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
270 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
