Question about Whirlpool MH1150XM Convection/Microwave Oven
We replaced the light in the hood (over the stove) and there was a spark and now neither the hood nor the microwave works. We reset the circuit breaker but it did not fix the problem. Do we need a buy a new one?
  • Whirlpool Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you prefer, you can order a new control circuit board and install it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below), remove the damaged circuit board and insert the new one.
Some connectors on the relays have a lock:
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.microwavesvc_10.jpg
Posted on Jan 02, 2011
All the burners are turned off on my gas stove, but one keeps sparking uncontrollably...its been all night now. I have lifted burner cap off and can see the spark but have no idea how to stop it. Our...
This is dangerous.
You should be able to stop it by unplugging the stove. The automatic spark requires electricity to work.
Unplug it and leave a comment with the make and model and I will assist you in finding a replacement.
Mar 31, 2011 | Microwave Ovens
THE STOVE TOP LIGHT ONDER THE MICROWAVE BLEW OUT. WHEN I REPLACED THE BULB BOTH LIGHTS NO NOT WORK.
Sounds like a power source issue from under the hood.
Unplug or turn off all power and take a closer look in there,. alternatively - this may sound crazy, but are you certain both bulbs are working by testing in another fixture??
Jan 05, 2011 | Sharp R-1480 Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
When I was unscrewing a burnt out hood lamp on
I would not use the lamps. Sounds like there is a shortage in the wiring for the lamps. They lamps should run together, and if one of the sockets have a short or burned wire it will not let it complete the circuit. This could be a fire hazard, so I would replace the whole microwave. It would be more trouble to tear it apart and find the exact problem than it's worth.
Jan 04, 2010 | Maytag MMV4205 Microwave Oven
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Lights fan and carosel do not work
tricky one. common denominator to all parts not working could be open neutral track at back of the circuit board, or possibly a relay not switching correctly.Need testing equiptment for that.
Sep 13, 2009 | Microwave Ovens
Presently have a regular hood, would like a microhood. How many inches clearance do I need between the top of the stove to the bottom of the cabinet?
This is a good question to ask at the point of sale. The measurement varies for different models and makes, but 33 - 36 inches is ideal. If you have a 12 or 15 inch tall cabinet above the stove, you are fine. A microhood does require a dedicated electrical circuit. When powewring off the current hood circuit, check to see if any other lights or outlets go off.
Jul 07, 2009 | Microwave Ovens
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
GE MIcrowave model JVM1631BJ01 hood lights won't work
The part that controls that is goes through your control panel on your microwave. For the lights to come on to start with the door being closed switches have to be working right and when you press start the lights come one. When the microwave is through cooking and you open then close the door then the lights should go out. The logic IC on the control panel board that detects all these events is not being reset correctly. Unless you get a microwave tech to track down the component on the control panel circuit board it is not something that you could do on your own since it takes voltage and signal checks with the proper equipment and then some soldering and desoldering of the defective component(s). Good luck and God bless.
Dec 22, 2008 | GE JVM1631 Microwave Oven
Whirlpool MH1150XM Convection/Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
