Question about Acer Aspire 4720 Notebook
Screen Flickers when I open the screen. - Acer Aspire 4720 Notebook
    Guru:
  • 679 Answers
Adjust the refresh rate of the display.
Click Start, click Control Panel, click Appearance and Themes, and then click Display Alternatively, right-click the desktop, and then click Properties.
Click the Settings tab, and then click Advanced.
Click the Monitor tab, and then click the screen refresh rate that you want to use.
Let me know if i understood it. Also, please do not hesitate to let me know if you need any further assistance.
Posted on Jan 01, 2011
  • Acer Master
  • 6,771 Answers
You may have a intermittent cable that connects the motherboard to the lcd screen. Hook a external monitor to the video output on the back of your laptop to see if you have a clean picture, if you do suspect the cable or loose connection.
  • Acer Master
  • 4,338 Answers
If the screen flickers, it means that the cable between the system board and the LCD is loose . You need to lift the keyboard and reseat the cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: My Gateway mx7118 lcd flickers whenever screen is opened,closed,
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 14, 2009
SOURCE: The screen flickers when opening laptop.
It's one of two things, either it's the backlight inverter or it's the switch which tells the laptop the lid is closed.
The backlight inverter is what powers the lamps in the back of the screen.They aren't expensive, but a computer shop will probably charge you an arm and a leg to replace.
The switch tells it to turn the backlight off when the lids is down to save power.
If it's the switch, you can disconnect it by following this guide http://forum.notebookreview.com/showthre… and http://forum.notebookreview.com/showthre… according to that if it thinks the lid it will turn the blue touchpad LED orange to indicate the touchpad is locked.
Posted on Jun 02, 2010
Screen flickers black when laptop is moved too much, and also when opening the screen.
you have a possible ribbon cable going bad to the screen you can see this exact cable on you tube,just place replacement screen with the model number and you will see the location of cable.
Jan 08, 2015 | Toshiba Satellite M305D-S4830 Notebook
Dell XPS 2710 Win 7 screen flickers when you open browswer on full screen. Also flickers badly when playing any games.
Could be Graphics Issue.
Try Resetting Internet Explorer.
Have you tried different browser?
Try rebooting in Safe Mode with Networking and check?
Let Me Know
Thanks
Feb 01, 2014 | Dell XPS One 2710 All-in-One Desktop
Lg tv gray screen main menu screen flickers
tats something in the board its self youll have to take that to a tv repair man
Dec 06, 2013 | LG Televison & Video
Jun 02, 2010 | Panasonic Toughbook CF-51 Notebook
Toshiba L300 screen flickers and backlight
Maybe is the backlight power cable cut. Try with the laptop in power on mode oppening VERY SLOWLY the screen to see if at a certain potition it works fine. Open it all the way up sometimes to check it. If thre is a potition that it works, it's the cable as I mentioned.
Stelios
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
N95 replacement screen flickers after 20 mins of
remove the screen and reinsert it.....may be some loose connections.. try using another screen...if problem persists then update the firmware or else change the screen....
Nov 24, 2009 | Nokia N95 Cellular Phone
Mar 13, 2009 | Gateway MX7118 Notebook
Screen flickers
yes i have had this problem before
the propper signal isnt getting to the screen from the mother board
has anything been spilt on the screen or the computer its self
i would suggest taking it to a tech they should be able to fix your problems
Jul 19, 2008 | Computers & Internet
Laptop screen sometimes flickers and gets jumbled up
it could be a problem of the lcd cable.
to fix this..the notebook needs to be opened up and lcd cable needs to be reseated
Jun 27, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Acer Aspire 4720 Notebook Logo
156 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
