Question about Roseart Toys
Horizon Group Power Balls Super Balls made by me! has no instructions, can you help?
From the box:
Cover work area with scrap paper.
- Decide which shape mold and colors you are going to use to make your power balls.
- Next snap together the two parts of the plastic ball mold
- Open the color crystals package that you would like to use first and pour the desired amount into the funnel on the top of the ball mold. Do not fill the funnel part of the mold all the way to the top or your ball will not bounce very well when you remove it from the mold.
- Holding the funnel part of the mold, carefully place the filled mold in a cup. While holding the mold, fill the cup with water right up to the bottom portion of the funnel. Let the mold sit in the water for five to ten minutes.
- Remove the mold from the water and wait ten minutes before opening it.
- Carefully open the mold and remove the ball. When you remove the ball from the mold it may feel a little sticky. Let it dry until it is no longer sticky before you start playing with it.
- Find a clean, flat surface to bounce the power balls on. When you are done playing, store each ball in resealable bags until you are ready to use them again.
Posted on Feb 19, 2011
Code 701 06 comes up
I have a T91 and first had the Lube Belt error. After lubing the belt and upon turning the unit on while holding the Stop (Not necessary according to instructions by horizon but I did it while powering up anyway) button down, the 701 06 was momentarily displayed. The unit then displayed the Lube Belt warning again. Lemme know if you hear anything, I am working on it.
Burt
Nov 17, 2013 | Horizon Exercise & Fitness
My Standard Horizon HX850S is not receiving on any channels. GPS works fine. Transmission is fine as well. Thank you so much for your help. MO
Hi Marius,
Not being a nautical person, I can't give you any advice with the following exception: join yahoo group SPECIFIC to your radio Make/Model, they will send you all the info required, plus you can download manuals, diagrams and other goodies.
I hope this helps you.
Cheers,
Peter
Jan 21, 2013 | Standard Horizon HX850S Two-Way Radio,...
What is the difference between 8 ball and 9 ball billiard?
Eight Ball is played with a cue ball and fifteen object balls, numbered 1 through 15. One player must pocket balls of the group numbered 1 through 7 and the other player has 9 thru 15. The player pocketing his group first and then pocketing the 8 ball wins the game.
Nine Ball is played with nine object balls numbered one through nine and a cue ball. On each shot the first ball the cue ball contacts must be the lowest-numbered ball on the table, but the balls need not be pocketed in order. If a player pockets any ball on a legal shot, he remains at the table for another shot, and continues until he misses, fouls, or wins the game by pocketing the 9-ball. After a miss, the incoming player must shoot from the position left by the previous player, but after any foul the incoming player may start with the cue ball anywhere on the table. Players are not required to call any shot. a match ends when one of the players has won the required number of games. You can read more here: http://departments.weber.edu/wildcatlanes/billiard_rules.htm
Jul 09, 2012 | Sport & Outdoor - Others
My Horizon T101 treadmill has power coming in from the power outlet but when I plug in the key it does not start. Please help. Is there a battery on the key?
no there isn't, in fact the key is a magnet plate mechanism but you should try attacking the problem by first checking the fuse which is located at the head end of the machine. If that doesn't work then remove the motor cover and get a qualified electrician/technician to check the circuit board for any possible faults.
hope this helps
Apr 07, 2011 | Horizon Fitness Horizon T101 9 Program...
While checking out the problem i was having with my super S&S type E carb, two small ball bearings dropped out. I kind of suspect where they go, but am not quite sure. can you help?
They go in the accelerator pump. There is also a very small spring that goes into one of the holes. These are the "check valves" for the accelerator pump. You can download a drawing at S&S site. Go to this site and download instruction sheet # 51-1012 for Super "E" and "G" carbs. There will be two small balls and one of them will have a small spring. It goes in the hole closest to the brass drain plug.
Good Luck
Steve
Mar 10, 2011 | Harley Davidson FXSTD Softail Duece...
We have the 3 in 1 fashion tie dye kit and have misplaced the direction it is made by horizon group usa
GO TO HORIZON USA GROUP WEBSITE AND GET THEIR NUMBER AND CALL, THEY WILL HELP YOU, I HAD TO DO THE SAME FOR ANOTHER ONE OF THEIR KITS
Feb 01, 2011 | Toys
Lost lubing instructions for treadmill and tool ex wife took them
Horizon fitness sells silcone gel lubricant or many stores also carry it.
Gerritt
Serving the Twin Cities
Mar 12, 2009 | Horizon Exercise & Fitness
Power cord
I called standard horizon myself and bought the power cord for $25. The # 714-827-7600
Nov 12, 2007 | Standard Horizon CP150 GPS Receiver
Toys Logo
1,268 people viewed this question
Top Roseart Toys Experts
Tom Chichester
Are you a Roseart Toy Expert? Answer questions, earn points and help others
