Question about Sharp LC42SB45U 42 in. LCD TV
Picture wont fit screen Menu choices on screen and the ones in the manual are not the same
Picture is to large dont have remote how do i fix it with out one its a sharp lc42sb4sut
Posted on Jan 22, 2012
Picture doesn't fit the screen
Its a function of the source and the tv picture settings. Go to the source (direct tv, cable, co-ax?) menu , settings and look for screen display sizes.
Your remote has a red dot "wide" button which will also have a screen size effect. You can cycle through the formats
For further info why not read/print out the manual?
http://store.vizio.com/documents/downloads/hdtv/L32/Manual.pdf
Mar 19, 2014 | Vizio L32 32 in. LCD HDTV
Emerson 32 HDTV LCD...my picture is smaller than the screen. How do I make the picture fit the screen. I'm missing a few inches of the images on both side...?
Most Emerson remote controls have a "FORMAT" button. Each button press cycles through TV Screen aspect ratio choices, such as Normal, Movie Expand, Wide, Zoom, etc. Pick one that fills your screen. You will probably have to change this setting again, depending on the signal source or channel selected.
The button cycles through the choices in a loop, so you can always get back to Normal.
Mar 24, 2013 | Televison & Video
Bought dlux2 but can't change from raw mode in menu to jpeg. Dont see anynjpeg/raw choice on menu.
The picture quality setting is in the REC mode menu. Your four choices are TIFF, JPEG Fine, JPEG Standard, and RAW. See the "Quality" section in the manual (page 74 in my copy). If you need a manual, you may download a copy here.
Dec 18, 2012 | Leica Digilux 2 Digital Camera
Phone wont ring
Press MENU/SELECT to display menu when in idle mode.
Press up/down to reach Setup HS. Press MENU/SELECT.
Press up/down to reach Rin g volume . Press MENU/SELECT.
Press up/down to scroll through the choices and a sample of each ring
volume will be played. Press MENU/SELECT to confirm.
The screen displays Stored and youll hear a confirmation beep.
If you need a manual, you may download one here.
Feb 17, 2012 | Vtech Cordless 6041 Phone
Is there a code number that needs to be entered to bring the convergence pattern or menu on screen.
From a user standpoint you would follow these steps to bring up your Convergence menu:
1) Press your MENU button.
2) Press the Right Cursor Button to enter the Picture menu.
3) Press the Down Cursor Button until you highlight the MANUAL CONVERGENCE choice on the menu.
4) You will then see the following choices on the right hand side of the menu: Convergence Red, Convergence Blue, Multipoint Red, Multi Blue, Save Multipoint.
5) Once you choose either the Red or Blue choices you will get a crosshair in the middle of your screen. You will then use either your Up, Down, Left, or Right Cursor buttons to get the two images to line up correctly. If you still have multi images on your screen in either Red or Blue you would then have to adjust the Multipoint choice for that color.
May 14, 2011 | Philips 51PP9100D 51 in. Television
Need to change tint, color on screen using the remote of course
Since you do not provide the make and model number of the TV so we can look for the user manual for you to read on how to make adjustment to your TV.
You just have to get to the MENU button on the remote for the ON screen setup menu and look for Picture adjustment set up to adjust the Pictures.
It should show Brightness, Contrast, Tint, Color adjustment choices.
Jan 03, 2011 | Televison & Video
My phone wont send media messages its a samsung eternity
My wouldn't either. I went in to "Menu"- "Messaging"-"Message Settings"- "Multimedia Messaging"- "MMS Profiles". I had 3 choices on the next screen... Since I use AT&T I checked 'AT&T MMS" My other choices were "media Net and AT&T IMS" Media net was checked but after I changed it to "AT&T MMS" I was able to start sending pictures and videos. Hope this helps. ~CherylofTexas~
Dec 20, 2009 | Samsung Eternity Cell Phone
Can't find finalize program on on screen menu
Select DVD drive, use right navigator and look for DVD management  page under other functions. That should offer you a finalize disc choice.               Or if disc is not full, try adding one more file small enough to fit, and finalizing should be automatic. Your disc may not be able to be finalized if your EH 55 didn't create it in the first place.                   Ricardo
Mar 18, 2009 | Panasonic DMR-E55 DVD Recorder
Picture size
This setup can be found in your manual that came with the tv on page 38
you may also download it at the following address for free.
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Digital Setup
This setting allows you to set the image of Digital
broadcasting.
Video Setup
You can adjust the settings for Digital image.
Screen Size
Set the format of image of Digital broadcasting.
1 Press MENU and the MENU screen displays.
2 Press < > to select “Digital Setup”.
3 Press ^ v to select “Video Setup”, and then
press ENTER.
4 Press ^ v to select “Screen Size”, and then
press ENTER.
Press < > to select “Manual” or “Auto”.
Manual is default auto is optional
since all tv channels do not broadcast in the same definition auto would be recommended
Selected item Description
Manual
Broadcasts in formats other than
480i will be converted and
displayed in the 1080i format.
With 480i broadcasts you can
change the screen size to the
size of your choice.
Auto.
All broadcasts will be converted
and displayed in the 1080i
format.
Nov 27, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Sharp LC42SB45U 42 in. LCD TV Logo
135 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
