Delonghi dfl 610 manual - Washing Machines
Dfl-800 loses connection
i have the same problem!!! have you fixed it? How?
Thx
F.
Nov 06, 2012 | D-Link DFL-800 (DFL800) Firewall
Unable to reset Dlink DFL 700 network firewall
To perform a factory reset using the reset button do the following:
Step 1: Make sure that the DFL-200/DFL-700 is on.
Step 2: Press and hold the button located on the back of the DFL-200/DFL-700 below the word Reset using a paper clip for 10 seconds.
Step 3: Release the button.
Oct 23, 2009 | D-Link NetDefend DFL-700 Firewall
Wan1 port not working in DFL 800 , can I use wan2
Yes, you will need to duplicate your wan1 configuration for wan2 and then move the cable. If you have any specific problems, please repost and we'll help you further.
Jul 08, 2009 | D-Link DFL-800 (DFL800) Firewall
I need to reset the password
reset the router to default settings by pressing on the reset button for ten seconds. (usually located at the back of the unit)
May 12, 2009 | D-Link DFL 500 (DFL-500) Firewall
DFL-260 Fierwall setting for Static IP
All of these info below are available in the owner manual that you can download here :
D-LINJK DFL-260 Firewall
You can either do it true command line or with the web interface.
Apr 09, 2009 | D-Link NetDefend DFL-200 Firewall
Port forwarding?
You can follow the steps on this link, click here. This is the steps on how to setup port forwarding for pc anywhere on a DFL-200. There is big possibility that the DFL-80 might have the setup configuration page as the DFL-200.
I hope this one helps.
Jul 07, 2008 | D-Link DFL 80 (DFL-80) Firewall
I need configuration aid for the DFL-210
Dear Sir/Madam,
Please check this link for more details. It may be help you.....
ftp://files.dlink.com.au/products/DFL-860/Manuals/NetDefendOS_2.12_User_Manual_v1.05.pdf
Thanks
Don't forget to rate the solution
Mar 06, 2008 | D-Link NetDefend DFL-200 Firewall
DFL-200 WAN won't connect
might be the WAN port failure because of the lightining>so only possiblities is replace it
Oct 30, 2007 | D-Link NetDefend DFL-200 Firewall
All Public IPs
In order to use your DFL-200 as a firewall, and not a router, you will need to put it into "transparent mode." This will allow you to use only public IP addresses and you will not be using NAT.
Jun 20, 2007 | D-Link NetDefend DFL-200 Firewall
NAT Traversal
NAT traversal refers to the common problem in TCP/IP networking of establishing connections between hosts in private TCP/IP networks which use NAT devices Client-based IPsec VPN connections often do not work when passing through a NAT device as the IKE and IPsec protocols were not designed to work through NAT. NAT Traversal is an add-on to the IKE and IPsec protocols that allows them to work when being NATed. NAT traversal is only used if both endpoints support it. D-Link products that currently support NAT traversal include the DFL-200, DFL-700 and DFL-1100. Note: The DFL-80 and DFL-300 do not support NAT traversal.
Feb 16, 2006 | D-Link Express EtherNetwork DI-804HV...
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
