Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
When baking the oven doesn't bake evenly and always bakes quicker than the time on recipes. Items burn and the middle is raw. Can the oven be recalculated to work better?? John
    Problem Solver:
  • 10 Answers
Electric ovens are always different from gas ovens. You have to set the temperature on average 10-15 degrees lower and watch out 15 minutes earlier if you are baking cakes, 5 mins for cookies etc. Always bake in the centre of the oven. use a metal bowl of water in another tray which may help balance out the temperature
Posted on Jan 11, 2011
I have a Tricity Bendix Built in oven TBS749. I have problems when baking as previously tried and tested recipes do not bake properly with burning on the top but the inside not cooked. I had noticed that...
Have you tried to turn the oven on to preheat and observe that the upper and lower heating elements alternately go on and off? Could be that 1 of your elements is burnt out and need replaced.
May 02, 2017 | Ovens
Smoke comes out of top when cleaning oven. Oven takes way to much time to cook. Oven does not cook evenly. Items cooked in oven are burnt outside and almost raw inside.
hello jjm... these ovens have two heating elements. when one is bad they still heat but they bake way too slowly. this is the problem here. the fix is to replace the bad element but in my repair service I always replace both heating elements since when one goes the other is usually not far behind.
Apr 28, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Why do cakes sometimes collapse while baking?
helllo dis.... There are many things that can cause cakes to fall in the middle.... Jumping, etc., around the baking area is unlikely to be a problem except with very delicate sponge or angel food cakes. More likely, cakes fall when the crust appears to be done, but the batter is not baked through the middle. An uneven baking temperature is a frequent culprit; check the temperature of your oven with a separate baking thermometer, and be certain that your oven holds a steady heat through the entire baking period. Some older ovens preheat properly, then cycle off and drop the temperature after 15 or 20 minutes, which causes the uncooked portion of the cake to fall.
Less likely but possible problems could be inaccurate proportions of baking powder or baking soda if the cake is made from scratch. This could occur with cake mixes if sour milk or buttermilk is used instead of regular milk; the additional acid in sour milk requires additional baking soda to rise properly. Eggs that are not beaten properly, or perhaps beaten too much for the type of cake being made, might also cause problems. Joe
Mar 12, 2011 | Tecnik Ovens
I have an bajaj oven and im trying to bake a cake and everthg i bake it the sides of the cake get baked and the middle portion remains raw..ive tried all the up flame,down flame and also both the up and...
if your oven is gas its is very difficult to make perfect baking of of the uneven heating,if your oven is elecric is with convection that one good compare to gas oven on an electric oven without convection, the advantage of oven the with convection is even heating.
Dec 24, 2010 | Ovens
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
Oven does not bake evenly.
We placed the pan in the exact center of the oven and backed it for 10min longer than what the recipe stated.
Dec 29, 2008 | Whirlpool SB160PEE Gas Single Oven
I have to cook way longer than recipe says.
This is usually caused by a weak oven ignitor. As they age, they seem to perform less effectively. Sometimes the oven will take several minutes to ignite the first time, and even worse on subsequent ignition cycles, resulting in overall low oven temp and poor baking. Replace the oven ignitor. Note, if you have a self clean gas oven, the ignitors are usually the same part number for the bake and broil, so you can try moving the broil ignitor (which is generally used much less than the bake ignitor) to the bake burner if you want to test it out before buying a replacement ignitor.
Nov 28, 2008 | Kenmore Ovens
Baking with digital oven
First let me address the temp ... Buy a meat thermometer and test it against the temp set in the oven.  Though that isn't the most accurate, it should prove whether or not it is way way off.
Second.. convection baking takes considerably less time....
Third... elevation plays a key factor on baking but not so much on cooking meat.  Baking above 2500ft elevation takes 20% longer and above.
Mar 08, 2008 | GE Profile JTP18 Electric Single Oven
Trouble baking
Sounds like it's running too hot. Check temps. May have a stuck relay on board. Run oven and check to see if bake element is cycling off when it reaches temps. It should stop glowing within
15 minutes from start. If it doesn't you need a relay board most likely.
Nov 04, 2007 | Jenn-Air JJW8330D Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
298 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
